Old 08-23-2018, 07:20 AM
Merritt5 Merritt5 is offline
Default Rear control arm bushings
Is there any benefit to running Delrin vs poly bushings in rear control arms?
Here is a control arm I'm designing for my mustang. I'm moving the sway bar forward to clear my panhard bar.
1993 Fox Body...its in the works
https://lateral-g.net/forums/showthread.php4?t=54321
1972 Nova...OUT OF THE BARN!!!!!
IG:@kdmerritt5 for more
Old 10-17-2018, 05:21 AM
RidiCat69 RidiCat69 is offline
Have you already built these, Merritt5?
Ryan
69 Cougar
Old 10-17-2018, 07:04 AM
I have not, but instead of using a urethane or derlin bushings, I may go with a johnny joint.
I can weld it to the frame side and use a rod end on the rear end side.
https://www.currieenterprises.com/CE-9112P-12
Old 10-17-2018, 08:10 AM
So if you use a Johnny joint, you’re relying on the ARB inself to keep the LCA from rotating. Or have you found a Johnny joint that doesn’t twist? All the Johnny joints I’ve seen allow twisting just like a rod end.
Edit: completely missed your part number link. Read the reply on my email...doh! So with that, yeah...a stick ARB would keep the control arm from twisting, but as soon as you go to an aftermarket bar with a proper end link the LCA will twist, negating the ARB all together and causing some spring sketchiness. Or am I missing something?
Ryan
69 Cougar
Old 10-17-2018, 09:06 AM
Stock...a stock ARB, not a stick ARB. Fat fingered that one on my phone
Ryan
69 Cougar
Old 10-17-2018, 09:19 AM
By aftermarket bar, I assume you are referring to the maximum motorsports one that bolts to the rear end itself. With that bar, I could see the chance of the springs becoming unseated due to the lca's twisting. As long as the roll bar bolts to the lca's, I don't see that being an issue.
For me, I'll probably have coil-overs on all corners, before I go with the MM rear roll bar.
Old 10-17-2018, 09:35 AM
Honestly, I completely forgot about their bar! Last fox I did, we used the stock ARB mounting points on the LCA's and made our own splined bar mounts to swap out bars of different thicknesses.
In that case, your idea would work quite well. The johnny joints are definitely nice. Have used them on a couple different things with good results. Got ours from Ballistic Fabrication. Instead of a snap ring they use a threaded retainer for the race so the joint can be tightened as it wears.
https://www.ballisticfabrication.com...allistic-joint
Ryan
69 Cougar
