Old 09-28-2018, 05:50 PM
Default Ecu mountain ls Swapped first Gen Camaro
Wrestling with ecu mounting ..... found the only spot I can live with may be under the pass seat.
Has anyone done this ? Does it need to be recessed ? I think it might sit too high and need to b3 sunken in.
Any tips and in particular photos much appreciated
Sorry mounting not mountain
Old 09-28-2018, 08:09 PM
Musclerodz's Avatar
e38 or e67 should clear depending on the seat. an early computer wont clear
Mike Redpath
Musclerodz & Customz
facebook page
The Following User Says Thank You to Musclerodz For This Useful Post:
XLexusTech (09-29-2018)
Old 09-29-2018, 04:30 AM
Thank you that helps with my current over 5he top stress about th car. Spent two days at the shop working on the car at the shop and got 1/3 of what I planned to complete done
Old 09-29-2018, 07:33 PM
Gmachine1911's Avatar
I struggled with the same thing on mine. Finally decided to mount the ECM on the back of the passenger side inner fender and mounted the engine fuse panel in the glove box. Worked out well and had plenty of harness to reach everything. I mounted the ECM on rubber isolators and the harness comes thru a 2 piece grommet where the heater blower motor used to be.
If I were to do it over again, I'd move it up a couple of inches as it's a little tight with the heater/AC hoses running to the bulkhead but it's all plumbed up and working.
The Following User Says Thank You to Gmachine1911 For This Useful Post:
Old 09-29-2018, 08:05 PM
Looks great , my receiver dryer is right there
Off subject but you happen to have a part number for that lower radiator hose ?
Old 09-30-2018, 04:19 AM
Gotcha, well it was worth a shot!!
Not a problem at all, it's a Gates hose from NAPA, pn: 9662. I had to trim just a bit off the end(s) but it was close to begin with. Good luck!
