Old 09-12-2019, 07:55 AM
Bakaruda's Avatar
Bakaruda Bakaruda is offline
Default Battery Cable Route
I would like to know what the group thinks is the best way to run the main cable. I keep going back and forth on the under vs inside. Please provide your ideals and pictures if you have any. Thanks in advance.
Old 09-12-2019, 08:46 AM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
In side it will be better protected, but you'll need a grommet or bulkhead to go through the body. I'm running mine inside the car personally. That's how GM does it on new cars with the trunk mounted batteries.
Instagram- camaroaj
The Following User Says Thank You to CamaroAJ For This Useful Post:
Bakaruda (09-12-2019)
Old 09-12-2019, 03:05 PM
slimjim's Avatar
slimjim slimjim is offline
+1 for inside, for mine I placed the battery on the passenger side in the rear, ran the 1/0 along the passenger Side of the transmission and passed it through a grommet close to the starter. charge wire runs through a seperate grommet from alternator back to the battery via the drivers side of the tunnel.
NC
streamline 68 camaro
Build Thread here
The Following User Says Thank You to slimjim For This Useful Post:
Old 09-12-2019, 04:04 PM
ADY's Avatar
ADY ADY is offline
Curious, what's the thinking behind running a separate charge wire from the alternator to the battery?
-Adam
1968 Camaro SS
Old 09-12-2019, 04:12 PM
eville's Avatar
eville eville is offline
It’s usually done only when a solenoid is placed in the trunk to make the battery to started lead hot only during cranking.
Steve
'68 Camaro - 355", TKO600, SpeedTech Arms, ATS-AFX Spindles, Hotchkis Springs, Forgeline Wheels, C5 Brakes (Kore3), Holley Terminator EFI
Check it out Here
The Following User Says Thank You to eville For This Useful Post:
ADY (09-12-2019)
Old 09-12-2019, 04:32 PM
Bakaruda's Avatar
I appreciate the replies. I have always ran it under the car. I may go the inside route this time.
