Old 04-03-2020, 08:16 AM
paulk68 paulk68 is offline
Default Tanks Inc.
Hey All, I am getting ready to build out my 68 camaro tanks inc fuel tank and after reading some stories I was planning on making a few changes.
1. I was gonna order the Cork gaskets instead of using the Rubber ones supplied.
2. I was gonna upgrade to tube style fuel gauge sending unit instead of using the float style.
What do you guys think are these work the extra cost?
thanks
Paul
Old 04-03-2020, 09:19 AM
eville's Avatar
eville eville is offline
The gaskets yes, I've heard mixed opinion about the tube sender. Although as you saw on FB, I just used one.
Steve
'68 Camaro - 355", TKO600, SpeedTech Arms, ATS-AFX Spindles, Hotchkis Springs, Forgeline Wheels, C5 Brakes (Kore3), Holley Terminator EFI
Check it out Here
Old 04-03-2020, 10:04 AM
BBPanel BBPanel is offline
I did both as well but vehicle not on road yet.
Old 04-03-2020, 10:25 AM
ADY's Avatar
ADY ADY is offline
I have the float style and would definitely recommend the tube style as my gas gauge jumps up/down nearly a 1/4 tank in mild driving.
-Adam
1968 Camaro SS
Old 04-03-2020, 10:35 AM
The standard stuff works fine, but the standard ventilation of the tank sucks if you have any pumping volume over that of a Walbro 250; even this is pushing it, especially if you plan to drive through turns with some enthusiasm (hot weather of course adds to expansion problems). Gasket sufficiency (and sender accuracy) hinges greatly on how effectively your tank is vented, kind of like with turbo pressure in an engine's crankcase. It took me years to figure this out, but hey, life is about learning, right?
Old 04-05-2020, 02:12 PM
andrewb70's Avatar
I would use the Rick's restomod stamped tank that uses the 5th Gen Camaro fuel module.
I have a Tanks, Inc. tank in my Cougar, and it works fine, but you can't beat the modern fuel modules. I originally was using the Walbro 255 pump, but found it annoyingly loud. I then replaced it with a DW200 pump, which is virtually silent.
Andrew
Instagram @dr__efi
I deliver what EFI promises.
My YouTube Channel
The Following 2 Users Say Thank You to andrewb70 For This Useful Post:
Corey R. (04-24-2020), minendrews68 (04-26-2020)
Old 04-05-2020, 02:52 PM
Ketzer's Avatar
Ketzer Ketzer is offline
Using the tube type in our FJ40 LS swap with a Boyds Welding tank, really like it.
Jeff-
Old 04-26-2020, 08:06 PM
minendrews68 minendrews68 is offline
Andrew
I too switched out my Walbro for the DW 200 pump. I have to blame Andrew for this! I didn't like the sound of the Walbro. To me it was annoying and loud. Some people have no problem with this, but I insulated just about everything I could with rubber and it still bothered me to the point I started asking questions on what pump was quieter. Andrew directed me to the video (in the above post) and I immediately bought one. Luckily, when I went to put this pump in I also ordered the stainless steel door that you put in the trunk. By far, two of the best moves I've made yet. I'm telling ya' you can stick your head in the trunk and barely can hear this thing humming. The stainless door, I think everyone should do this that may have to pull the tank for one reason or the other.. Thanks again Andrew!
The Following User Says Thank You to minendrews68 For This Useful Post:
andrewb70 (04-26-2020)
Old 04-13-2020, 07:10 AM
72Z/28's Avatar
72Z/28 72Z/28 is offline
Well I changed my fuel gauge sending unit from Floating to the Tube style sending unit. Unfortunately, did not notice any difference as the gauge kept swinging/jumping up and down in normal driving.
Not sure whether it is the gauge issue or the tube style sending unit.
I replaced my old classic instruments gauges last week and put new autometer gauges but have not driven the car yet.
However, I have read in one of the forums that you cannot get rid of fuel slushing because the tank is not designed with proper baffling. In fact, Summit racing now put a note when ordering tanks in their website as well.
72 Camaro RS:SOLD
68 Camaro:
Old 05-03-2020, 05:20 PM
Mean Buzzen 6 Mean Buzzen 6 is offline
Question
Was wondering if you can install a Holley HydraMats ?
https://www.holley.com/products/fuel...mat/hydramats/
