Old 06-16-2020, 08:57 AM
thedugan's Avatar
thedugan thedugan is offline
Default Ls7 wet sump crate engine now available
https://gmauthority.com/blog/2020/06...-crate-engine/
Doug L.
68 Camaro RS/SS Conv. LSA/T56
67 Camaro RS LS2/T56 "NutKse"
Old 06-16-2020, 12:17 PM
Originally Posted by thedugan View Post
found it .. 12K. https://www.gmperformancemotor.com/parts/19420191.html
Old 06-16-2020, 06:22 PM
JKnight JKnight is offline
I was intrigued by the new LS7 option...but It made me take an even harder look at this one: https://blueprintengines.com/product...ads-roller-cam
Old 06-17-2020, 03:41 PM
It uses ls3 block without longer sleeves and greater then 4 in stroke.. thats a piston rocking cylinder and piston skirt wearing combo..
No thanks ..
The Following User Says Thank You to XLexusTech For This Useful Post:
pannetron (10-28-2020)
Old 06-17-2020, 06:05 PM
Appreciate the info. I had planned to revisit my under square, square and oversquare research as well. Do you think they resolved the valve issues on the recent crate engines that some production LS7 issues had? Or was that mostly an “interwebz” issue?
Old 06-17-2020, 06:36 PM
I recommend taking a gander over at LS1TECH .. Much info there.. If I were to be buying a motor right now in the budget range your haunting in .. 10 to 12 K I would be looking LSA>.
https://www.texas-speed.com/p-8256-g...e-engines.aspx
or NA 408 from texas speed or similar..
