Old 02-09-2021, 05:25 AM
Jay Hilliard's Avatar
Default What Clutch Master to use?
Trying to determine best hydraulic clutch MC to use. Either Tilton or Wilwood. What are you guys using and how is the engagement, pedal feel (modern factory feel, softer, harder like mechanical)?
The MC's i'm looking at are:
Tilton 75-750 (3/4 bore w/1.1" stroke) or 76-875 (7/8 bore w/1.1" stroke)
Wilwood 260-15091 (3/4 bore w/1.25 stoke)
I know typically 3/4 bore is preferred, but if the stroke is borderline not long enough, bore size can be increased to provide more flow.
thanks,
Jay
Jay
Old 02-11-2021, 11:33 AM
gnx7's Avatar
gnx7 gnx7 is offline
On all of my T56 Swaps I run the 7/8" bore MC since 2004.
The Following User Says Thank You to gnx7 For This Useful Post:
Jay Hilliard (02-12-2021)
Old 02-11-2021, 11:11 PM
I used a Tick Performance master setup for a 4th gen camaro (Tilton 7/8") with my Monster LT1-S clutch/T56 Magnum combo. Pedal effort is perfect, not too heavy and easy to modulate. Clutch is fully disengaged well before the pedal is fully depressed.
The Following User Says Thank You to MtotheIKEo For This Useful Post:
