Old 11-29-2021, 11:30 AM
71OLDS's Avatar
71OLDS 71OLDS is offline
Default Lime Green 71 Olds convertible
Hi All. Starting a new thread here for my updates. Been years since I've posted an update here. A few recent pics:
Will add build details and more pics soon.
-Joe
Joe Lincoln
1971 Olds 442 Convertible & 1970 Cutlass Supreme
The Following 4 Users Say Thank You to 71OLDS For This Useful Post:
camcojb (11-29-2021), Roscoe03 (11-30-2021), syborg tt (09-25-2023), WILWAXU (12-02-2021)
Old 11-29-2021, 11:58 AM
71OLDS's Avatar
1971 Olds 442 Convertible (Original 442 4 speed car)
paint code 43 - Lime Green
468 Olds 528@5500hp/563@4300tq (dyno from 2013), Torker intake, Edelbrock Performer RPM 6051 Heads, 69ccs 11:1CR (93 Octane)
Crane Hyd roller: 288/300 @ .006, 234/246 @ .050, 592/614 (1.65), 112, Morel roller lifters, Diamond Pistons, Rocket Racing 7" rods
Go EFI 8 Fitech - with hand held unit hidden in ash tray
Aeromotive Phantom stealth 340 in-tank electric pump
Canton Racing 15-502 baffled 6 qt oil pan
Oil cooler with Oil filter relocated
Ignition: MSD 8566 dist, MSD Digital 6 plus 4500/6200 2 step/Rev limiter, MSD 8207 SS coil
Alternator: powerbstrd 220 amp alternator (110 at idle)
1 7/8" x 3 1/2" Jet Hot coated Supercomp headers, 3" exhaust with X pipe into 3" Olds trumpet tail pipes
Tremec Magnum 6 speed close ratio (2.66 first)
Factory Olds 4 speed console, 67-69 Hurst "442" chrome shifter handle topped w/large white 2.25" 6 speed Hurst shifter ball
McLeod street twin
Hyd clutch from American Powertrain
12 bolt Chevy rear 4.10 gears - axel tubes welded to pumpkin, Mosier Axels-TA Perf girdle cover
3 1/2" Chromoly drive shaft balanced to 9000 RPM - no vibration in 6th gear w/4.10s on hwy
AFX Spindles w/A body specific alum steering arms to correct bump steer =.8" drop and 1.2" drop SPC 550 rated 14 1/8" front springs (not coil-overs) = 2" total drop in the front
SPC upper/lower front control arms w/progressive rate jounce bumpers on the lowers
Hellwig 5703 1 5/16” solid front sway bar w/SC&C Extreme duty swivel end links
SC&C front Chassis brace
Custom front fiberglass spoiler
Currectrac rear upper articulating arms
UMI rear dbl adjustable articulating lower control arms. Note: Currectrac were too long at 22” - had to switch to UMI which can be shortened to 21 3/8” to center rear wheels/rear end in wheel wells.
SPC 1"drop 135 rated 14 1/4" rear springs w/air bags inside for rear seat passengers/pre-load for drag racing launches
UMI 1” chassis mount adjustable rear sway bar - custom settings for street/drag race/auto-cross/road race
UMI relocation brackets #4012 - custom settings for street/drag race/auto-cross/road race
Varishock dbl adjustable shocks front & rear - custom settings for street/drag race/auto-cross/road race
Lee 800 12.7 steering box
Baer Brakes 13" front, 12" rear
Manual w/Hydroboost
BE-COOL aluminum radiator w/dual electric fans
Wheels: Schott "Magnum"- Olds SSI w/Olds Rocket custom caps
18x11 rear w/305/40s, 18x10 front w/265/40s for drag race/street
19x11.5 rear w/325/30s, 18x11 front w/315/30s for autox
fiberglass parts: hood, front bumper, , rear decklid, and factory rear spoiler w/custom 3rd brake light added
6 pt roll bar w/removable cross bar & door bars
custom shoulder harness belts built into main hoop for street - converts to 5 pt harness for track
3rd brake light custom fit on underside of factory rear wing, front parking lights converted to daytime running lights (always on)
Stereo: 70-72 Olds USA-740 radio 5 channel RCA pre-outs with subwoofer control and USB port, front speakers = high output Boston Acoustics Pro Series 5 1/4” split channel – replaced Custom Autosound speakers inside the kick panels, flush mounted 5 ¼” Boston Acoustic CRX57 2 way speakers in the rear. Kicker 12” sub CompRT loaded enclosure (one passive) and Alpine PDX-V9 5-channel car amp = 100 watts RMS x 4 speakers and 500 watts RMS to sub. Trunk is boxed in and carpeted
Battery in trunk, pwr windows, factory 8 track, factory tilt, pwr trunk (open via factory button in glove box or key fab - gas shocks added to trunk so it opens slowly since it's so light with everything being fiberglass), AC, line lock built into factory cruise control button, 2 step for launches
Older pic to show car fully painted:
Joe Lincoln
The Following 3 Users Say Thank You to 71OLDS For This Useful Post:
camcojb (08-17-2023), fleet (08-20-2023), syborg tt (09-25-2023)
Old 11-29-2021, 12:03 PM
71OLDS's Avatar
Joe Lincoln
fleet (08-20-2023), Roscoe03 (08-16-2023), syborg tt (09-25-2023)
Old 11-29-2021, 12:51 PM
I LOVE the look of those cars.
Old 11-29-2021, 12:58 PM
71OLDS's Avatar
Thanks Jody - been following your build - incredible work!!
-Joe
Joe Lincoln
Old 11-29-2021, 01:16 PM
71OLDS's Avatar
future plans:
ordered my new wheels for autocross:
front 18x11 - will be running 315 30 18s
rear 19x11.5 - will be running 325 30 19s
working on design/plan for hood vents:
finished product vision pics - planning around hood stripes:
working on design/plan for front splitter. Going to try to make it quick release so I can run with or w/o front splitter with fast/easy change.
Joe Lincoln
The Following User Says Thank You to 71OLDS For This Useful Post:
