Old 10-09-2006, 09:50 AM
WhitecatD WhitecatD is offline
Default Cost to make 1000hp
how much would a basic set up cost to make 1000hp? Nuthing fancy like polished intakes or anything like that. I was looking at the Banks twin turbo set up for a small block.
62 Nova 400 Under Construction
64 Pontiac Catalina
Old 10-09-2006, 10:45 AM
Speedster's Avatar
Speedster Speedster is offline
The first question is: The cost to hit 1,000 hp for bragging rights, or the cost to hit 1,000 hp consistently without failure? Also race gas versus pump gas.
Just asking since it makes a huge 2x/3x difference in price.
-Bruce
Project "Freebird"
Dyno Video
http://www.nelsonracingengines.com/...lownbbchigh.wmv
Project Rides:
1968 Firebird - Blown 540
1987 Blazer 4x4 - Blown 355
2007 Magnum
2010 Camaro SS - LSX Twin Turbo
Old 10-09-2006, 10:54 AM
HRBS's Avatar
HRBS HRBS is offline
Also, old school displacement (cubic inches) with a big carb(s) or new age technology (twin turbo's, fuel injected etc). Hardcore race or streetable tuning ? NOS or Naturally aspirated ? As you can tell, there are alot of variations to consider when trying to est a build cost. It is possible to achieve 1000hp with a TT small block but the challange as is relates to cost is achived when trying to make it (a) reliable and (b) streeable.
HRBS on Facebook
Old 10-09-2006, 11:06 AM
The Banks system is $6K or so. I'd recommend an intercooler which would add another $1000-$1500 easy with the plumbing. You can do without and add water/alcohol injection, but not an ideal situation.
You will likely spend in the $8K to $12K for a reasonable long block to handle the boost. More if you want to go bulletproof. That's also if you can do the engine assembly yourself, otherwise add $1500+ for assembly.
You could make the power for less, but if you wanted to be able to do it time and again it pays to use better parts.
Old 10-09-2006, 11:28 AM
rocketman's Avatar
1000 hp,
All engines making that hp level are going to be expensive,Forged cranks,billet rods,forged pistions are the only way to build a engine like this.Turbos,blowers,nitrous can all kill parts.I seen a guy at the dragstrip with a stock short block ls1,with twin turbos made 3 passes before breakin ther crank and 2 rods out the oil pan,which then dumped 7 qts of oil on the track and crashed the car.
Dn't try it on a stock parts.
To make 1000 hp will run between 8k and 16k.
Old 10-09-2006, 12:03 PM
syborg tt's Avatar
The question is do you realy need a 1000hp.
Can i ask another question - most is the most realistic HP number that you can make and it still be streetable
Just an Example the new LS7 is about 500hp and i would say it's tops what you use on the street
marty-mj
Old 10-09-2006, 04:40 PM
chicane's Avatar
chicane chicane is offline
1hp = $150 at the "good guy" price...
1hp = $200 at the "It will actually live long enough to drive it 50k miles" price.
Old 10-09-2006, 05:05 PM
JUSTANOVA JUSTANOVA is offline
http://www.ultrastreet.net/632_1000_bd.asp
a large X huge big block should do the trick.
