Old 12-09-2006, 08:50 PM
71Nova 71Nova is offline
Default Nova Door Hinges
I was planning on installing some new door hinges on my 71 Nova because my driver door droops about 2 inches when you open it. I was looking at the hinges today and realised that they look like they are welded on. I can't see any bolt heads. Both sides look the same. Is this normal? It seems like it would make it almost imposible to adjust the door gap. Was it done this way on all 71 novas or do you guys think this was done by a previous owner? I have not found any evidence in my 7 years of owning this car that it was ever in an accident.
David
Old 12-09-2006, 09:13 PM
68protouring454's Avatar
not sure if they are welded, could be, however more then likely the problem is the door pin bushing is toast and the door pin has elongated the hole big time, remove pins, weld up and drill for new bushings
Old 12-10-2006, 02:43 AM
Smack_talker's Avatar
Smack_talker Smack_talker is offline
Yeah the hinges being welded is normal. The adjustment is inside the door and replace the pins like the above poster said.
R.I.P Jenna Weaver, my "Little Peanut" 01-18-07 to 01-30-07. Thank you for 13 days that I will NEVER forget.
Old 12-12-2006, 03:16 AM
Thanks guys. I will give that a try.
David
