Old 01-09-2007, 01:29 PM
68RS350 68RS350 is offline
Default LS1 to a TKO500
Does anyone sell a bellhousing that mates an LS1 to a TKO500? Or do i have to get an adpater plate. Also do the clutches and flywheel all mate up?
Old 01-10-2007, 06:56 AM
dtedler dtedler is offline
I don't want to give you any bad information so...Call Jeff or Scott at Classic Chevy 5 Speed in California. I now they have what you need, but I don't know the exact particulars.
Their website is www.classicchevy5speed.com
Tony
Old 02-08-2007, 09:15 PM
parsonsj parsonsj is offline
Brian Schein and I made one that bolts to the factory bell.
It's been working great with both a QMI Tri-lite and Howe TOB.
Or you can use an aftermarket from either McLeod or Lakewood.
Or you can use a GM BBC 168 tooth bellhousing. The only problem with the GM bell is that most of them don't have the 12 o'clock bolt hole.
jp
John Parsons
Old 03-11-2007, 10:32 PM
jeffmort's Avatar
jeffmort jeffmort is offline
We do have one - it is a dedicated LS to TKO bell. It has all of the correct bolt holes for the LS block.
Jeff Mortenson
Classic Chevy 5-Speed
[email protected]
www.ClassicChevy5Speed.com
