Old 02-11-2007, 06:15 AM
Gr8t68's Avatar
Gr8t68 Gr8t68 is offline
Default 68 Camaro - Need some advice/help
Just got the rear qtr off on the driver side and found some damage (see the pics) to one of the panels behind the qtr from a previous engagement with a LTD wagon in the mid 80s. The question is, does anyone know where I can get a new one or what the proper name for this part is? Also, I need to locate a part that welds to the inner tub and connects to the trunk hinge. Is there an aftermarket piece availabe for this or will I have to fabricate one? As always, your comments are appreciated.
Old 02-11-2007, 06:33 AM
almcbri's Avatar
almcbri almcbri is offline
you need the "LH trunk floor to rear quarter panel"
The hinge part?? I don't believe they offer that part, but I may be wrong. I wish I still had my junked 68 bird. I find parts that I could have used all the time.
cya, AM
1968 Camaro LS1/T56, Hotchkis Springs, Tubular Arms, AFCO sway bar, C5 brakes, VWW 18" V40's http://s14.photobucket.com/albums/a3...1968%20Camaro/
Old 02-26-2007, 06:32 PM
hifi875's Avatar
hifi875 hifi875 is offline
Default trunk
its called a drivers side trunk dropoff or trunk support. i had to put 2 of them in my car.
Old 02-26-2007, 07:03 PM
Camaro Zach's Avatar
Camaro Zach Camaro Zach is offline
I have a pair of the brackets that go from the wheel tub to the hinge. If you want them send me an email - zachary188 "at" aol.com
AIM: Zachary188
'68 Camaro: www.cardomain.com/id/43zach
Old 02-27-2007, 06:51 AM
clill's Avatar
clill clill is offline
I think they reproduce the trunk drop off's.
Old 02-27-2007, 07:20 AM
comp-spec's Avatar
comp-spec comp-spec is offline
There called trunk drop offs U can get them from good mark industries $30.00
http://www.goodmarkindustries.com/HomePage.html
