Old 02-15-2007, 07:59 AM
Default LS1 block huggers
Hi everyone,
I'm building the 65 porsche with the LS1 motor. I have the engine in now and looking at header options. I have clearance issues and little room - so my options might only allow a block hugger type short header. My goal for the engine is 400 hp (intake, cam, headers and 2.5 exhaust). Is that possible with hugger style headers ? Is it a waste for little gain over the stock units ?
Here's what I've seen so far - if it helps
http://www.jegs.com/webapp/wcs/store...59625_-1_10605
Thanks for the help guys !
Jim
Old 02-15-2007, 08:14 AM
TravisB TravisB is offline
www.streetandperformance.com
will have some options for you
Kenny Davis Hot Rods
Old 02-15-2007, 10:13 AM
PRRC PRRC is offline
Are is a pic of the street & Performance headers we are using on an Ls2 project.They are a very nice piece.
www.paradise-road.com
Old 02-15-2007, 10:18 AM
Beautifull stuff ! I'll give them a yell. Thanks guys !
Old 02-15-2007, 05:25 PM
Rubes Rubes is offline
Hey Tim...shoot me some pics of that when you get the motor back in the chassis.
Old 02-15-2007, 06:33 PM
Will Do.
Tim
Old 02-16-2007, 05:32 PM
ironworks's Avatar
Sanderson makes some nice ones, I have used the street and performance ones on other projects and they have a huge collector with that square flange deal that they have.
You know if your doing all this work on you car, I know you can build your own set of headers. ten you could have long tubes that fit. Headers are intimidating, but not that hard once you get the hang of things. header kits are the way to go.
Just my 2 cents. I have never had much luck with block hugger headers. Plus when you use block hugger header, you have to connect the exhaust which goes down from the flange and makes a 90 degree bend. Even if you start the bend at the header flange you have a minimun of 7-8" until the bottom, so it winds up taking more room.
Check out those headers in the 66 nova project, they took 23 hours to the point you see. But they clear and are removable.
Rodger
