Old 03-27-2007, 12:09 AM
Default Twin Intercoolers vs. Single
More intercooler discussion here. I searched and could not find any discussion on this topic so here is my thread.
We (my builder and I) are thinking of doing twin IC's instead of a single for a few reasons.
-to be a little different than most
-for an aesthetically pleasing look (to me)
-to line up with the air vents in the lower valance I want to run
Now, this is what I could not find anything on. Is there a disadvantage to this except maybe a little added cost? I see some ProCharger kits (I saw a C5 kit) use twin IC's. Is this is less efficient than running a larger single IC? Maybe the C5 kit used them out of necessity and less space under the hood?
Any insight is appreciated. FYI, I have the ProCharger D1SC.
Old 03-27-2007, 05:01 AM
Diesel77's Avatar
Diesel77 Diesel77 is offline
I think the only real way to measure efficiency would be from inlet temps and flow and or from dyno pulls using a single and then a dual IC set up. But then again unless it was in your car and driving the temps would be different being as the air hitting your ICs would vary on both set ups going thru your grill, or wherever the clean air is coming from. If your ICs are getting good air and they are sufficient to support each turbo's HP and or desired boost, then I dont think you should have any efficiency problems. There is no real way to test this for any application unless you run a single IC in your car and get some real data and then install 2 dedicated ICs for each turbo and check inlet temps and backpressures to see if the single or dual ICs cause a loss in turbo efficiency due to higher back pressures and or a loss of HP.
88MonteSS
TurboneticsTwinTurbos
CSU 850 BlowThru
https://www.youtube.com/watch?v=qH13mJ3-vSk
https://www.youtube.com/watch?v=EZYB1PtiOng
Old 03-27-2007, 07:54 AM
camcojb camcojb is online now
As above, tough to say without testing both combos on your vehicle. But the idea of two vs one should not be an issue at all as long as each intercooler is efficient enough to not be a restriction and remove the amount of heat required for the combo. In other words, splitting one into two should not be a disadvantage, as long as they're the proper build and size. The problem may be that to get two twins as efficient as a single may require very large twins, and they won't fit.
Old 03-27-2007, 09:18 AM
deuce_454's Avatar
well the eficiency of the intercooler is determined by the area and mass and speed of the air passing over the surface (both being a sum of many factors) but lets for the sake of argument asume that you were first to try and run a large single intercooler partially hidden by a valance.. and were then to saw it in perfect halves (with an infinitely thin saw) and re mounted the two halves in better airflow... then youd be better off efficiency wise.. also the total area of the intercooler piping should be greater when running two instead of one.. also you should have shorter combined length of the pipes...
but in all honesty, on a twin turbo setup, you have the capacity to over power any chassy.. regardles óf intercoolæer configuration, so the answer in the real world is propably that you wont know the difference driving the car... and besides if you like two intercoolers... run two! its your car, you can do whateher you like (cool huh?)
Jake: Hit it.
Old 03-27-2007, 09:24 PM
Thanks for the quick feedback guys. I at least feel okay about the possibility of running the twins now, and as much as I want maximum power and efficiency, it I sacrificed a little power (that I wouldn't know about anyway because I won't be dynoing both setups) then it wouldn't be the end of the world...
I may have found a great deal on a slightly used twin setup with plumbing, so that may be the ticket.
thanks again!
Old 03-27-2007, 10:42 PM
californiacuda californiacuda is offline
water/meth injection
