Old 04-16-2007, 08:17 PM
bigtyme1's Avatar
bigtyme1 bigtyme1 is offline
Default LF vs RT Golden Legion Doors
OK, 69 Camaro I have new LF and RT doors. when they are mounted with perfect gaps I need to use 2 washers on the driver side striker, My first thought was the 1/4 were off. But after measuring I found out the Door frames are different from left to right. where the stricker meets the door. The right is 1" from stricker area to the edge of the door. on the left side its 1 3/8" from stricker area to door edge. I bought the doors 2 years ago. So I called the guy and he said no problem bring them back. Tonight we opened up two brand new left doors and they are the same 1 3/8 to the edge. Me being a perfectionist I really want to use the Stainless strickers and they should match on both sides with out washers. What can I do to make it work. I know theres alot of you using after market door how did you get them to work and be even?
69 RS Ragtop
[email protected]
Will trade wife for parts!!!
Old 04-17-2007, 09:30 AM
96z28ss's Avatar
96z28ss 96z28ss is offline
Machine one of the door strikers longer.
Old 04-17-2007, 09:53 AM
bigtyme1's Avatar
That's what I was thinking, I just wasn't sure how hard it would be. I guess I'll have to ask pasqual.
69 RS Ragtop
[email protected]
Old 04-17-2007, 06:56 PM
B Schein's Avatar
B Schein B Schein is offline
My car has original doors and had three washers on the passengers side and on the drivers side from the factory. Where did you buy the doors from sounds like Dennys. He is always good about letting you return stuff you have had for a long time.
Brian
Old 04-18-2007, 03:09 AM
bigtyme1's Avatar
yea Denny is a great guy, he even told me if I find one that was correct he would give me my money back. Are you from the area?
69 RS Ragtop
[email protected]
Old 04-18-2007, 06:49 AM
The striker is not your real problem area. The real trouble is in the door rubber area. Put the rubbers on it before you do anything else. typicaly when the outer skin is lined up, the inner shell is off so much the rubbers will not allow the door to close.
I HATE repo doors. I would rather fix any original door then use any repo door. The other probelm is that they are soft as hell, and if you look at it them worng they dent / ding.
Frank Serafine
