Old 08-11-2007, 01:55 PM
akrapovic's Avatar
akrapovic akrapovic is offline
Default Is this the right cam for my setup?
First and foremost I appreciate all the in I have received from the members. That being said I need more help I was advised that the 215cc dart heads I have may be too much for my 350 (.30 over) 4 bolt. It was also mentioned that this setup may work with a big enough cam. here are the motor specs along with the newly aquired cam specs.
Is this the correct setup with 215cc heads?
Cam specs(Motor specs below)
COMPETITION CAMS PART NUMBER: 12-513-5
ENGINE: CS 280TLS-6
GRIND #: CS 280TLS-6
INT EXH
VALVE ADJUSTMENT: .018 .020
GROSS VALVE LIFT: .530 .550
DURATION AT
.020 TAPPET LIFT 280 288
VALVE TIMING OPEN CLOSE
AT .020 INT 38 62
EXH 74 34
THESE SPECS ARE FOR CAM INSTALLED
@ 106.0 INT C/L
INT EXH
DUR @.050: 250 259
LOBE LIFT: .3530 .3660
LOBE SEPARATION: 106.0
RECOMMENDED CC VALVE SPRINGS: 950-16
Motor specs
* .30 Over 4 Bolt Main Block
* Forged - 1970 350 Z-28 Crank w/one Piece Rear Main Seal
* Comp. Solid Flat Tappet Cam
* Chevy "Pink" Forged Rods
* TRW 10:1 Forged Flat Top Pistons
* Melling Hi-Vol Oil Pump
* Morosso Oil Pan 8 QT/Baffled
* Edlebrock Victor Jr. Alum Water Pump
* Edelbrock Victor Jr. Intack Manifold
* Barry Grant 750 CFM Silver 4 Bl Carb (flows 933 CFM)
* Morosso 1" Phenolic Spacer
* MSD Pro-Billet Distributor
* MSD 6-AL Distributor
* Hooker 1 3/4" Suer Comp Headers
* Dart Pro-1 (Angled Plugs) Heads 2.05 INT/1.60 EX 215 cc Runner & Guide Plates
* Scorpion 1.5:1 Fully Rollerized Alum. Rockers
* Fluid Damper 6 1/4" Harmonic Balancer
* Lakewood Stamped Scatter Shield
* Front Drive Shaft Loop
* Super T-10 4 Speed (Rebuilt 8/00) w/hard racing parts
* Hurst Super Shifter
* Hays Borg & Beck type Street/Strip Clutch Disk & Pressure Plate
* 4 Wheel Stock Drum Brakes
* Grant Steering Wheel
* GM 10-Bolt Rear Housing Posi 4:11 Gears
* Auto Meter Guages
* 3" Aluminized Exhaust
* 2 Chamber Flow Masters
* New Battery
* Front Tires BFG Comp TA 195/60
* Rear Tires BFG Radial TA 275/60
* Polyurethane Body Bushings in 2000
* Polyurethane Sway Bar Bushings & Idler 2000
* Comp Frame Connectors 2000
* Lakewood Slapper Bars
* AM/FM Cassette w/Power Antenna
* Use 20W-50 Synthetic Oil
* Engine rebuilt 2001 - 2002
Old 08-17-2007, 11:13 AM
markss28 markss28 is offline
I do think that is a bit much for a 350 but if it were a 383 you should be right were you want to be. Even though you could still run that head on your current setup it will just not be optimal. The you've picked is good and should be agressive enough for the heads. If you were running any lower in compression then 10.1 then that would be bad. The good thing is that you have everything but the crank (3.75) to make a very strong street strip motor. If it were a 383 I think 500hp would be about right.
Never Stay Stock
