Old 08-25-2007, 08:55 AM
Yan69 Yan69 is offline
Default New Box or Rack and pignion
Good day, im getting into major work on my 69 vert and wondering what you guys think. The steering is really loose, so should i get a new box or swap for a rack and pignion kit? keep in mind that i will be keeping the stock subframe. i"m also wondering if its cheaper to go with an after market subframe with coilovers,new upper and lower C arms and a new direction than purchasing everything separately and keep the stock subframe.
thx for your input, its worth a million bucks.
Yan
Old 08-28-2007, 06:37 AM
no ideas anyone?
im really confused on what to do here.
is upgrading my stock subframe with all the goodies more expensive than getting an aftermerket complete kit and sould i stick with a steering box on a sock subframe ?
thx
Old 08-28-2007, 08:41 AM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
When all is said and done, figure about $6,000 plus for a good handling aftermarket subframe.
On the other hand you can (as I plan to on my '67) run the ATS (www.t56kit.com) extended spindle, your stock UCA/LCA, del-alum UCA/LCA bushings, aftermarket front springs and good shocks, a 3rd generation IROC steering box and a good swaybar and (assuming everything else is in good condition - wheel bearings, ball joints, steering linkage, etc.) have a very nice handling front suspension for about $1,500 to $2,000 depending on the specifics of what you do (particularly shocks).
Tubular control arms don't contribute to good handling and aren't needed. The bolt on R&P systems won't perform nearly as well as a good box.
Old 08-28-2007, 09:01 AM
thx for your advice , much appreciated.
yan
Old 08-28-2007, 11:52 AM
Marcus SC&C's Avatar
Since you mentioned stock subframe I`ll stick to that. We`ve instaled and tested a few of the R&P conversions for the stock subframes and honestly I`ve never been impressed. It`s a really tough job stuffin a R&P into an envelope that was never intended for one and then making it work as well as a modern car that was designed around a R&P from the ground up.
The factory steering gear on the other hand,while certainly not ideal has had 40 years of R&D done on it and a lot of good has come out of that. The bumpsteer issues can be fixed with a bumpsteer kit or our tall tie rod ends and manufacturers like Lee have developed valving curves for blueprinted fast ratio Saginaw boxes that yield exceptional steering feel and control even by modern standards. This for a fraction of the price of a R&P conversion and a lot less work since you don`t have to mess with adapting the R&P input shaft to the steering column.
A quick word about Mkelcy`s reply. I more or less agree with it except for a few point on tubular arms. It`s not the tubular part that makes them worth having and some in fact actually do nothing at all (except look cool). Some alter the static alignment bay adding more caster and are shorter allowing more - camber at lowered ride heights. That`s a good thing because although it`s not really altering the geometry per se the alignment works hand in hand with the suspension to make the car work well...or not. When significantly lowering a car,when installing taller spindles or tall ball joints that effectively increase spindle height,or when doing the G MOd and especially when doign 2 or more of these things in combination the normally droopy stock arms swing upwards and also outwards giving you a bunch of + camber that you have to get rid of. Considering that it`s usually not possible to align bone stock early Camaros to modern performance specs due to lack of room for shims on the rear stud you`re pretty much out of luck. Now you may have a car with some really good suspension parts on it that drives like a shopping cart because you can`t align it properly. Also watch the angle and travel of the upper ball joints, taller effective spindle heights,lowered ride heights,the G Mod and stock upper arms can contribute to putting the upper ball joints in bind before you achieve full bump travel. That`s not a good thing and can eventually lead to suspension fatigue and breakage most likely resulting in a very bad day. To summarize,bolting stock spec tubie arms on a bone stock car won`t do a thing for you but using the proper A arms on a well modified car can make all the difference in the world. Mark SC&C
Old 08-28-2007, 08:16 PM
Gandalf Gandalf is offline
Useful info as usual Mark - thanks!
Old 08-29-2007, 03:19 AM
ProTouring442's Avatar
Besides, aren't packaging and weight the reasons modern cars use rack and pinion? I know that untill recently, and I think they still do, Mercedes uses the old box & idler arm style on their cars.
Shiny Side Up!
Bill
Never met a man with real talent who felt the need to deride the efforts of other.
Old 09-19-2007, 09:15 AM
UNISTEER's Avatar
UNISTEER UNISTEER is offline
Yan
We have the bolt-in rack kits for your car in Manual or Power, Black or Chrome (shown below) finishes.
If you are interested in a modern gear box; we are now offering the best steering box ever offered by GM- Delphi. The GM “600 series” Power Steering Boxes were originally designed for NASCAR.
The GM 600 Box is slightly lighter than other power steering boxes and is available in several different ratios for optimal steering performance depending on the vehicle; 12:1, 14:1, and 16:1 ratios are available for this steering box. We offer this box alone or with the necessary rag-joint (coupler) and adapter fittings that enable you to use your existing sttering hoses.
We also offer the correct GM Type II/TC power steering pump that is internally adjusted for the proper fluid flow and pressure to give you the very best “Box & Pump” steering available.
We are currently offering a 10% discount & FREE SHIPPPING (to lower 48 states only) for a period of 60 days on anything we sell.
So if you are interested in improving the steering of your ride take a look at our website and use the discount code: LATG-10
www.unisteer.com
800-338-9080
