Old 09-26-2007, 11:23 AM
ironworks's Avatar
balsa wood
Old 09-26-2007, 11:28 AM
ironworks's Avatar
Originally Posted by HWY Nova
I'm sure Rodger will set up some licensing agreement in order to share his knowledge....
Eric you have hung out with me long enough to know that there is no knowledge, just luck.......
Old 09-26-2007, 07:12 PM
dave96dcm dave96dcm is offline
Originally Posted by ironworks
balsa wood
Wow I would have never guessed that, I guess that it is true that you learn something new every day. Is that a common way to do a floor on a frame like that?
Old 09-26-2007, 11:39 PM
novanutcase's Avatar
novanutcase novanutcase is offline
Dropped her down to ride height(4.5 at the cowl!) to make sure wheel clearance is OK! Rodger wanted to see what it would look like with big rotors so he stuck his truck rotor on the back wheel!
This is how we decided to finish the diff cage! I couldn't bear to cover up the beautiful tube work so we're just going to leave her as is! Just got to finish off the corners!
Sub floor is all tacked in!
John
Old 09-27-2007, 06:04 AM
HRBS's Avatar
HRBS HRBS is offline
John... have you and Roger thought about a throttle pedal yet ?
That looks pretty tight.
We had a similar problem when I slammed the Impala. The tunnel became so wide that it limited the room for a pedal. I bent the stock assembly bracket and fab'd up an 's' shaped arm. Works but is still kinda tight. Yours looks even tighter.
HRBS on Facebook
Old 09-27-2007, 06:46 AM
Payton King's Avatar
Default I have said you car is so cool so many times
it is like playing golf with my friend with a 0 handicap....you get tired of saying great shot. LOL
I love the big rotor look on the rear.
Old 09-27-2007, 08:46 AM
HWY Nova HWY Nova is offline
Default Throttle Pedal
Rumor has it that John has little feet, but he has a big....... wallet.
--Eric
ET
62 Nova Coupe
62 Nova Convertible @ Ironworks Speed & Kustom
Old 09-27-2007, 09:15 AM
TravisB TravisB is offline
Default floor
what thickness is the sheetmetal inside the car?
Kenny Davis Hot Rods
Old 09-27-2007, 09:21 AM
ironworks's Avatar
Actually the gas pedal is going to be designed by a aerospece engineer. Haha
Really it is....
Last I heard the rocket scientist was working on the brake pedals also. But the gas pedal actually has lots of room since it will be a hanging pedal. I may not be able to fit my size 15 in the with room to spare. But John had foot enhancement by the doctor of the stars Dr 90210 so he has perfect feet,,,,Now. He does not need those cute driving booties, that I have.
ironworks's Avatar
18 gauge
