Old 11-16-2007, 08:58 AM
el-camino's Avatar
el-camino el-camino is offline
hi mark,
the dash comes from a 1985 BMW 535i, the modell name is E28
the series exist from 1982-1987
greets from Sweden
Klaus
Old 11-16-2007, 12:38 PM
John S John S is offline
Originally Posted by Marcus SC&C
Hey John,the Monte looks GREAT! Thanks to guys like you Spohn has made a lot of changes and tweaks in the arms. They even make a dedicated Varishock lower for us that`ll work with packages other than your G-5. I`d still like to see a bumpstop on them so folks don`t have to mount one to the frame but that`s about my only issue with them and that`s not a huge one because it`s easily fixed. We do have the new SPC lower arms coming out in the next week or two though. They`re a real step ahead of every other lower arm on the market with improved geometry (we`ve even compensated for centering the wheels in the wheel wells with increased + caster settings),GM bumpstops (ZQ8 are a 2min. bolt in), greasable delrin bushings std.,and they accept either std. coil springs (with laser cut shims to adj. ride height up to +.75" or -.75"!) or coil overs. We`ve been working with SPC on them for almost 2 years now! We brought the cost in at just $514pr. too. They`re going to be THE choice in lower arms. The Spohns will remain a really good (now) budget alternative though.
Klause,awesome BMW dash swap! The small heater box would make things so much nicer on big block cars too. What year/model BMW is it out of?
Mark SC&C
Thanks to guys like us, or BECAUSE of guys like us?
OK mark, I'm always in for better but... What are my lowers worth on trade in? I've invested so much already that I would really need some more incentive to change the lowers again. I'll even send you the plans on modifying Alston's junk adjuster tool so that it will actually work on a G body.
Old 11-16-2007, 01:14 PM
deuce_454's Avatar
marcus you %&#"#!!! now youve gone and ruined my cristmas... guess what ill be needing soon?
oh well, il buy the lower controll arms when i can see a picture of them on your homepage....
did you get the box shipped btw?
Jake: Hit it.
Old 11-26-2007, 01:45 PM
el-camino's Avatar
order is done
Mark, let the parts out with direction Europe
greets from Sweden
Klaus
