Old 12-01-2007, 10:23 AM
XTRMEASURES's Avatar
XTRMEASURES XTRMEASURES is offline
Default many turbo questions
Hello guy's i'm in the process of buying a car from a member here and also want to start planning the build. I have question's cuz i'm new to turbo's and want to do this right the first time. My first question is will a crate motor (ZZ4-ZZ383) work with a twin turbo setup. What about tran's, auto or manual or does it make different. I would like an auto but if the manual would work better then that's what i'll do. The car will be something i drive but also hit the track ever so often. And last were is a good place to buy turbo's.
thank's i'm sure i'll have more question's later.
Old 12-01-2007, 12:32 PM
J2SpeedandCustom J2SpeedandCustom is offline
Any motor can be good for turbo's if its got the correct parts inside it. Do you want to source a custom kit or buy and off the shelf setup?
Jeff Allen
J2 Speed and Custom
Old 12-01-2007, 01:18 PM
Thank's for the reply, see i do'nt know if the ZZ4 or ZZ383 is good enough cuz i dont know anything about turbo's. As for buying im not sure there either. If you could show me some site's that sale turbo's and kit's.
Old 12-01-2007, 02:40 PM
Out of the crate the zz4 might be able to handle a small amount of boost without breaking. The bottom end and heads will need work and strengthening of you want longevity / reliablility.
Pick up Corky Bells "Maximum Boost" and go to one of his websites - http://www.bellengineering.net/ Also check out http://www.bankspower.com/twin-turbo-products.cfm for some info on a kit. Gale and Corky in my opinion are the ones to learn from.
The best way to turbo a car is to do the research and determine which setup is best for YOU. What do you feel comfortable with fuel injected, carb blow through, super charger, turbo, etc. Take the time and you'll only buy things once and enjoy the car much more.
Jeff Allen
J2 Speed and Custom
Old 12-01-2007, 04:45 PM
01somta 01somta is offline
When it comes to trannys it doesn't matter if it is a manual or auto. If it is for drag racing purposes an auto would be better due to not lossing as much boost in between shifts.
Old 12-01-2007, 05:11 PM
you guys are being very helpfull
so i might just build a motor then buying a crate engine if i would have to change parts anyway.
A man that's motivated will find a way.
PROJECT'S
1984 GMC swb truck
1972 Camaro
2013 GMC truck
Old 12-01-2007, 07:44 PM
Here are a couple sbc and bbc shortblocks that are built for boost. You can also look through their turn key engines and get one with a 9.5:1 CR. The turn key motors come with a 2 yr. unlimited mileage warranty.
http://www.ultrastreet.net/poweradder.asp
Old 12-01-2007, 10:19 PM
i think i found the short block im going to go with.....
http://www.ultrastreet.net/poweradder_short_sb.asp
the stage 1 406 cu in for $4770.00
thanks
PROJECT'S
1984 GMC swb truck
1972 Camaro
2013 GMC truck
Old 12-02-2007, 07:23 AM
About this time last year I finished up a DIY turbo build on my 93 mustang that had a stock 302sbf short block with alum. heads and 150k miles. At 9psi it put down 532rwhp with out a dyno tune, it took about 3 months to build and about 3k. I had no turbo experience when we started and with help from a friend (mechanical engineer) it was a breeze. I also used alot of info from turbomustangs.com (not just for mustangs now). Just make sure that you get a good wideband or a/f guage, do a boost leak down test, and do the best that you can to keep your under hood temps down. You can't bet the feel of a turbo and the car had very good street manners. That was one of the cars that I wish I would not of sold. Here are a couple pics, when we were completely finished the engine bay looked alot cleaner.
Old 12-02-2007, 07:27 AM
Here are a couple videos of when we first cranked it over.
