Old 03-31-2008, 06:19 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Default Distilled water and Deionized water
Distilled water and Deionized water is there a big difference? Ready to fill the new radiator I bought and it says to use Deionized water. Not sure where to even find it. Is it o.k. to use Distilled water instead?
Curtis
Old 03-31-2008, 06:56 PM
7TSS's Avatar
7TSS 7TSS is offline
Distilled water is actually better than the deionized water that you get through home water filtration systems. I've been using distilled water with good results.
Old 03-31-2008, 07:01 PM
Spiffav8's Avatar
Lateral-g Moderator
Thanks for the info. I re-read the directions and it says to use one or the other. If all goes right I'll be able to fire the car up tomorrow!
Curtis
Old 04-01-2008, 09:39 AM
Dark Angel's Avatar
Dark Angel Dark Angel is offline
Just dump water in it!!!
'01 Onyx Z28 12.75 @ 113.24
'67 Camaro 327
'72 El Camino
'87 'Burb. 6.2 Turbo Diesel
Old 04-01-2008, 10:27 AM
Steve1968LS2's Avatar
Fire?
Sure you wanna use that terminology???
Old 04-01-2008, 11:00 AM
DDY RCKT's Avatar
DDY RCKT DDY RCKT is offline
Originally Posted by Steve1968LS2 View Post
Fire?
What you should do is take bottled water, boil it, collect the steam in an autoclaved and sterilized container, and use that. That way, there'll be no contamination in your coolant system. You did sterilize and autoclave your engine post assembly, didn't you?
2002 Corvette Z06
Old 04-01-2008, 06:59 PM
Dark Angel's Avatar
Fire?
Actually I think that was almost the case!!
Damn alternator lugs!
'67 Camaro 327
'72 El Camino
Old 04-01-2008, 07:05 PM
Spiffav8's Avatar
Lateral-g Moderator
Fire?
Been spending 10 to 12 hours a day on the car all week. Pretty much put everything else in my life on hold trying to get the car finished. If it doesn't run tomorrow (yes another days delay) I might just torch it in the drive way out of frustration.
Curtis
Old 04-01-2008, 08:19 PM
thats a pretty cool picture. Blow it up and hang it up on the wall behind the car
Old 04-01-2008, 08:39 PM
Spiffav8's Avatar
Lateral-g Moderator
Thanks! It was Aj's idea...maybe I should hang it up in his garage.
Curtis
