Old 07-10-2008, 07:15 AM
syborg tt's Avatar
Looks way better to me, as I pictured a light colored wheel with the darker paint. I just wish this new camera took a decent picture; I've tried every setting, even called Kodak, and it just spits out poor quality pics. The car looks much better in real life, but here's a few pics to get a good idea of how it ended up.
Hi Jody,
The car looks incredible.
Try taking picture of the car at Dawn or Dusk.
It looks way to sunny and that is why you can't see the contrast on the wheels.
marty-mj
Old 07-10-2008, 09:13 AM
61Bubbletop's Avatar
61Bubbletop 61Bubbletop is offline
Lateral-g Moderator
Car is just fantastic Jody...the detail and forethought you put into it really shine through.....I hope you get that pesky issue worked out (you will, I have no doubt)...INCREDIBLE car!
Old 07-18-2008, 08:16 AM
kwhizz's Avatar
kwhizz kwhizz is offline
Jody...........What's the latest..........?????
Ken
Old 07-18-2008, 10:11 AM
Ken
Ken,
the crank was tapping the side of the pan after I re-did the turbo drain line; it was pushing the oil filter hoses into the side of the pan enough to make it just hit on the front throw. It was super close to begin with since I run a Callies stroker crank. I had pulled the engine to powdercoat the pan, and so I clearanced it first and then took it to the powdercoater. I went ahead and pulled the engine down just to have a look, everythings perfect.
It's almost back together, just waiting for a head gasket from Chevrolet which should be here today, and the pan from the powdercoater.
Old 07-18-2008, 12:05 PM
ccracin's Avatar
ccracin ccracin is offline
Jody,
You are certainly dedicated to this project. Pulling that work of art apart, wow. Better safe than sorry! I hope to get to see it some day. Great work.
Later,
Chad
Instagram - @cctek
68 Chevy Pickup Project
