Old 11-21-2008, 02:03 PM
Roadrage David Roadrage David is offline
Default Who hase /sells the best GM A body sway bars money can buy!!!
Need new ones......
Old 11-21-2008, 08:38 PM
The WidowMaker's Avatar
dse sells the best front. splined bar using bars acquired from speedway. with over 100 different rates and only $130 each to swap out, tuning is almost infinite. at $800 for the kit, its waaaaaaaaaaayyyyyy over priced, but their pillow blocks and arms are pretty sweet. im going to fab up something myself since i already did a splined bar for the rear.
"The WidowMaker"
Old 11-21-2008, 08:47 PM
Blown353 Blown353 is offline
Mark @ SC&C is getting close to releasing his drop-link adjustable rate rear A-body bar as well... I'd wait for that. The factory rear bars on A-bodies are rather ineffective due to the mounting method.
The DSE splined front bar is nice, but rather spendy...
1969 Chevelle
