Old 12-15-2008, 05:25 AM
deocon deocon is offline
Default 68 Mustang from the Philippines
I retired 5 years ago. So I have sometime doing cars that I would like.
It was then the height of the Eleanor craze so I tried to do one. I found a good body that cost me about $1000. Since buying the Eleanor kit and shipping it to the Philippines will be very expensive so I did everything in steel.
Old 12-15-2008, 05:31 AM
I wanted to put the largest Ford engine and I found a 460 for $500. To ease installation I opted to remove the shock towers and move the engine 10 inches to the rear.
And since moving the engine 10 inches to the rear will live a large void in front so I tried fitting 4 small turbos.
Please understand that this project will be done using 2nd hand parts to be cheap, since performance parts are very expensive in the Philippines.
Old 12-15-2008, 05:41 AM
Another shot of the engine bay with 4 turbos, 2 intercoolers , pipes are custom built. Oil and water supply for the turbos will be a dedicated system and separate from the engine.
http://farm1.static.flickr.com/184/4...f553fefd6a.jpg
Old 12-15-2008, 05:46 AM
I also found a complete C4 Corvette suspension and adapted it to the Mustang.
Surprisingly, it was a fit!
Old 12-15-2008, 05:51 AM
Here are the steel conversion photos.
Old 12-15-2008, 06:00 AM
68protouring454's Avatar
looks good, but why are there pics of 2 different cars?
Jake's Rod Shop
Old 12-15-2008, 06:01 AM
Since everything south of the engine will be moved 10 inches also, I did a six point roll bar and made a custom dash.
Dash being painted.
Old 12-15-2008, 06:08 AM
The floors are all rusted up so I decided to remove the floor boards and do a space frame backbone.
Old 12-15-2008, 06:10 AM
The car has been turned to a true 2-seater.
Old 12-15-2008, 06:11 AM
Overhead console mounted on the roll cage.
