Old 01-30-2009, 12:21 AM
monmon030791 monmon030791 is offline
Default 572 Block?
Right now I just bought a 454 block with a 4 bolt main for $375. Basically to make it a 454 I need to get the 454 rotating assembly to make it a 454, can I make a 572 with this block. My friend said I need a 502 block or something like that and I was looking and GM performance parts and I'm pretty sure they use the same block I'm using with a 572 stroker kit? Am I right or wrong if so, what block do I need in order to get the stroker kit to make a 572! Thanks!!
Old 01-30-2009, 01:44 AM
holschen's Avatar
holschen holschen is offline
Default 572
you need a 4.5 bore and a 4.5 stroke
or a 4,3 bore and a 5,0 stroke
but i guess itīs best to 502 ,merlin3,and bore it to 4,5
my 2 cents;-)
camaro69-l92+6l80e-
speedtech(LCA)-ats Street-Comp AFX-unisteer r&p-VariShock
camaro 5gen rear
Hydratech Brake Booster
movit brakes 380mm 6piston front- brembo 465mm 4piston rear
275/30-19 front-325/25-20 rear
19x9f 20x12r cray scorpions
Old 01-30-2009, 01:49 AM
like what block exactly do i need to make a solid 572. Is my block the right one or do I need to take it back and get another one?
Old 01-30-2009, 06:49 AM
tgvettes tgvettes is offline
I thought you needed a tall deck block to go to 572 at least that is what the Chevy crate 572 are. I think pretty 496 is the biggest out of a std 454 block without stretching the limits to much.
Tonny
Old 02-04-2009, 09:09 PM
As far as i know 500ci up you need an aftermarket block the merlin can go to 700 something ci.
