Old 01-30-2009, 09:04 AM
clill's Avatar
clill clill is offline
Nope...
Old 01-30-2009, 10:28 AM
DOOM's Avatar
DOOM DOOM is offline
Originally Posted by rwhite692 View Post
GM's MSRP on the ZR1 brake components is $12,183
Gene Culley is currently quoting $8,999
This includes four calipers, four rotors, 4 sets of brake pads.. (ZR1's are 1 set of brake pads per wheel, and the calipers and pads do not come with the caliper pin kits.)
Some are of the opinion that these brakes, if not used with the corresponding electronic controls, might not perform all that much better than the current C6 ZO6 setup (as Scott has on his car).
There just isn't much data on how they would perform when retrofitted to something like an older musclecar, and operated without the controls... yet.
There are definately lot of things to consider, apart from just bolting them up...of course you need at least a 19" wheel...
Here are a few, from the Corvette Forums:
Be aware that if you track a car with Carbon/Carbon or Carbon/Ceramic brakes you MUST use/make further modifications due to the higher operating temps.
The ZR1 required different front spindle bearing assemblies, due to the extreme heating generated in the rotor. So, plan on changing hubs and spindles.
The brake fluid used MUST have a DRY Boiling point above 600*F. There are ONLY 3 choices currently available. WET boiling point is a concern but is secondary:
Make / DRY BP F* / WET BP F*
AP PRF 660 / 608*F / 390*F
GS 610 / 610*F / 421*F
Wilwood EXP / 626*F / 417*F
Thanx Rob
I have the same ones as Scott I'll stick with those... Thats all I needed to here...
Mario
USCOLLISION
Old 01-30-2009, 05:42 PM
Reiters Metal Reiters Metal is offline
body is yellow!!!!!!!! Mark is coming by in the morning to shoot sum pic's, pic's should be up tomorrow, Monday we'll get it rolling back on it's wheels.
www.reitersmetalcraft.com
Old 01-30-2009, 05:58 PM
clill's Avatar
That means you need to call Mark in the AM and remind him to bring his camera.
Old 01-30-2009, 06:10 PM
awr68's Avatar
awr68 awr68 is offline
No pics till tomorrow! Well at least it's painted!!
Tony
'68 Camaro
Old 01-30-2009, 06:14 PM
I'll make sure i do that!
Old 01-30-2009, 07:39 PM
Aschle's Avatar
Aschle Aschle is offline
I am anxious to see it !!!
Jason
Jason Aschle
________________
1969 Camaro
1957 Chevy 150 Utility sedan, semi-pro touring
2016 MB s-AMG E63
Old 01-31-2009, 11:53 AM
I can't wait to see it in color, I love Yellow Camaro's
Wayne
Old 01-31-2009, 03:21 PM
olds87 olds87 is offline
I can not wait to see the car have paint. Good luck Charle.
James W.
1987 Oldsmobile
Cutlass Supreme
Old 01-31-2009, 06:36 PM
awr68's Avatar
Pics.............................................. ......please!
Tony
'68 Camaro
