Old 05-02-2009, 02:58 PM
Your probably going to need 3 to get it where most of us on here run em.
Old 05-02-2009, 06:32 PM
Van B's Avatar
Van B Van B is offline
I had 2 inch and went to 3 inch and I don't think it is low enough. Not compared to the cars with coil overs. It is a nice driveable height, but not super low. Check the pics in my sig to see what it looks like.
Jeff
99 Miata LS6
67 Camaro Street Fighter 599 HP L92-SOLD
Old 05-02-2009, 07:18 PM
awr68's Avatar
awr68 awr68 is offline
Heres what normally happens, the owner looks at his car/measures and says I will go with the 2" lowering springs thinking that it will be perfect! But you have to remember thay your stock springs are very worn and the car is sitting lower than stock height...so when you go with the 2" springs it may actually not lower the car and possibly even raise it a tad.
Like the others have sad...go with the 3" springs if you want it sitting 'right', you may even have to run a 1" lowering block with the 3" springs.....
Hope this helps!
Tony
'68 Camaro
Old 05-03-2009, 01:01 AM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Ok scottybuck 11 here's a picture of my car with a set of GW 3" drop springs. It took a few months but it did come down from the height of the initial install, about 1.5". If you are still working on the car and it is not being driven, I would suggest leaving everything loose and keep some weight in the trunk. Get some measurements so you can track the drop. So basically don't panic yet. Maybe a few guys with the DSE 2" drop springs can post some pics for comparison.
As for any feelings of being stupid...you can totally dismiss those. Lots of guys have been in your shoes including me.
Curtis
Old 05-03-2009, 10:07 AM
scottybuck 11 scottybuck 11 is offline
i really appreciate all the help you guys have give me.this website is the best one i have been on to read posts and get help when i get stumped.if my car turns out to be what i want i will owe all of you guys alot of the credit for it.thanks for all the help.
scott buchanan
Old 05-03-2009, 10:21 AM
69x22's Avatar
69x22 69x22 is offline
Default leaf spring
If you got it little extra cash laying around, let Frank with Prodigy hook you up with one of his Prodigy 4 bars. Its simple to install, adjustable ride height, and rides quite a bit better than lowered leaf springs.
Old 05-09-2009, 07:32 PM
ok guys i got my 3inch drop springs in and thats got me about an inch lower but i still havent got everything in the car so i put 250lbs in the trunk and left everything loose so it will settle.once again thanks guys.
Old 05-09-2009, 09:55 PM
Spiffav8's Avatar
Lateral-g Moderator
Sounds good! Give it some time...sadly that's what it takes.
Curtis
Old 05-14-2009, 01:48 PM
just a little update.i put 250 pounds in the trunk and it has settled an inch.so im looking good now.
Old 05-14-2009, 02:13 PM
Told you dude.
