Old 06-15-2009, 12:47 PM
mike23109 mike23109 is offline
Default Turn Signal LED
I have a Covan's Classic dash and I think the LED for the left turn signal is out. I can't get them on the phone. (They won't answer and do not call back when I leave a message). I wan to replace the LED but don't know what to get. Any idea on the specs for this part? Or, are they all the same.
Old 06-15-2009, 12:51 PM
66zz430 66zz430 is offline
I used these : http://summitracing.com/search/brand.../?autoview=SKU
Old 06-15-2009, 01:15 PM
130fe 130fe is offline
Post
I don't know which ones you have, I used ones like these http://summitracing.com/parts/PRF-80202/ . They have a 3 mm and a 5 mm, I used the 3mm ones Got them at my local Radio Shack (they have red, amber and green, no blue though). Check your power and ground for that circuit. If I remember right, the turns signals were a light (left) and a dark (dark) blue wires off of the dash connector.
BTW, if you use a blue LED for the high beams, put it low and away from your main view, that thing is BRIGHT!!
Hope this helps you, if it doesn't let us know.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 06-15-2009, 05:32 PM
72 RS/SS 72 RS/SS is offline
Man, ain't that the truth. When I hit my brights, it's like a laser beam aimed at my eyes!
Old 06-16-2009, 12:03 PM
Thanks for the info.
