Old 11-24-2009, 05:15 PM
War's Avatar
War War is offline
Originally Posted by DOOM View Post
Jason I went through your build thread and have a question... Can you tell me what method you use for closing or opening the body gaps.
1/8" round bar and welder for closing, grindin and weldin for opening. There alot in of steps and it takes alot of time. I hammer and dolly edges as flat and thin as I can get before adding or removing material. On edges of quarters and such if there soft I will cut and add rod to get a sharp edge. You have to go slow and take your time with lots of hammer and dolly work. I seen some guys make a mess out of panels. Pacual said you can have your gaps out of bondo or metal, you choose.
I had to re-skin both doors and I fully welded the inside so there are no seams
Here is some pics of the doors
Jason
Old 11-24-2009, 05:21 PM
War's Avatar
War War is offline
Here some more of the doors and finishing some edges.
Jason
Old 11-24-2009, 05:23 PM
War's Avatar
War War is offline
Originally Posted by Bow Tie 67 View Post
I have the same questions? Also, will all the body seams be smoothed?
Most of the seams will be smoothed
Jason
Old 11-24-2009, 05:50 PM
DOOM's Avatar
DOOM DOOM is offline
Jason THANX!!
I get it now, this was a MAJOR concern with my build. So when you add the 1/8 inch round bar you then weld the bar the complete lenght of the edge correct Tig or Mig
Mario
USCOLLISION
Old 11-24-2009, 06:13 PM
bentfab's Avatar
bentfab bentfab is offline
Thanks !!!
Follow us on Instagram = @bentcustom
www.bentcustomandperformance.com
Old 11-24-2009, 06:59 PM
RECOVERY ROOM's Avatar
Supporting Vendor
RecoveryRoomInteriors.com
Very nice work,This will be something to see when done
TRACY WEAVER
www.recoveryroominteriors.com
Old 11-24-2009, 07:29 PM
ironworks's Avatar
If that's what your into I guess......
Old 11-24-2009, 08:38 PM
KPC67's Avatar
KPC67 KPC67 is offline
this car is awesome!
Great work!
Kevin Carter
Old 11-24-2009, 09:13 PM
Every time I come back to check I'm more amazed. You do beautiful work.
Thanks for sharing.
Old 11-24-2009, 09:27 PM
War's Avatar
War War is offline
Thanks Wayne, How's yours coming along?
Jason
