Old 02-09-2010, 03:50 PM
jr421's Avatar
jr421 jr421 is offline
Default BBC Tall Deck Question
Ok I am just wondering if anyone has installed a tall deck clock in a 1969 camaro? I am wondering if you rin into clearance issues with headers and other bolt-ons. I keep passing up deals on tall deck blocks the curiosity is killing me.
Old 02-09-2010, 08:37 PM
rocketman's Avatar
headers will most likely be a problem because depending on how tall of a tall deck you will want a longer length header,
most tall decks are only taller from above the timing chain up so most all aftermarket set ups should fit, stock brackets will need modded or could simply just need longer belts
