Old 02-23-2010, 02:16 PM
Default Hawk Pads
Looking for any input on Hawk compounds. Anyone happy with their setup with a mix of auotcross and road racing in mind? Unsatisfied with my Wilwood pads and their cold performance.
Old 02-23-2010, 04:08 PM
Payton King's Avatar
Default Todd
I will have some info for your soon. I have seen Carbotech on the corvette forum and lots of people swear by them...Tobin at Kore 3 told me to give them a call. They happen to be 15 minutes from my house. Anyway, I got a set of their Ax6 pads(autocross pad). The cold Cf is .52. Suppose to be easy on rotors, can drive them on the street but may be noisy with a little dust. If you are concerned about noise you can run their bearcats on the back. They stated these pads have won a number of national solo II events. They said for track for my car to use the XP12 on front and XP10 or XP8 on the rear. State to use a different compound on the back on a solid axle car to keep it for wheel hopping.
I will let you know about the noise, bite and dust by this weekend.
Old 02-23-2010, 04:16 PM
68protouring454's Avatar
i have been running 9012 blue on front and hp plus on rear, i like a less aggressive bite on my rear brake pads. the 9012s are alittle hard on rotors but the initial bite is well worth it.
jake
Jake's Rod Shop
Old 02-23-2010, 04:27 PM
Thanks Dudes...
Old 03-01-2010, 06:05 AM
Default Got the pads in and bedded
yesterday. Todd you know the problems we have had with not liking the feel of our brakes. Well I can finally say I am more than please with the feel and performance of my brakes. What a difference a good pad makes. The Carbotech Ax6 pad is outstanding. It dusts more than the BP10 but not as much as say your BMW. somewhere in between. So far no noise and it stops like crazy. I also changed fluid to a Brembo low compression and the feel of my pedal has never been better. These will be the only pads I run on the street and autocross. I will get another set for the track that will take that kind of heat. Probably the Carbotech XP12's on front and XP10's on rear.
Old 03-01-2010, 06:41 AM
Nice! The only time I've really liked my brakes was on the road course. I'll call them soon. What do you think about going to a 1 inch master with these pads?
Old 03-01-2010, 09:08 AM
Default I think you are running 7/8 tandum
from Wilwood. I personally would get a set of these pads and also try the Brembo fluid. I think it will give you the feel you are looking for...
I had a different type of fluid and my pedal was almost spongy for lack of a better term. The fluild changed the feel of my pedal completely.
Why are you looking to increase the master size...fluid volume for pad knockback?
Old 03-01-2010, 11:20 AM
chr2002ca's Avatar
chr2002ca chr2002ca is offline
That's some very interesting info about the brake fluid. I've been disappointed with my spongy pedal using Prestone DOT 5 Synthetic. After reading your feedback, I've gone ahead and ordered some of that Brembo SPORT.EVO 500++ brake fluid from Amazon.com and I'm going to give it a shot next weekend. Hopefully I'll notice the same improvement you did. Amazon had the best price I could find: 3 bottles shipped for $41.
Chris Robinson
1969 Camaro SS/RS, 489 ZL-1 MPFI, T-56 Mag
Old 03-01-2010, 11:46 AM
I've got a good firm high pedal except when racing when it drops but stays firm. You guessed it, the 1 inch bore would cut the knocback in another 1/3rd. I have one that was traded to me. I'm going to try the pads first and go from there. I didn't know any fluid was compressable?
Old 03-01-2010, 12:08 PM
Default I did not either
but it did make a difference. Not sure which Brembo fluid I have but that sounds right. Look on carbotech website and you will see what I used.
If you are using the DOT 5 stuff that is a silicone based fluid and should not be used in a performace situation. Make sure you flush it well to get all of that stuff out. I would purchase some DOT 3 or 4 stuff and use it to flush it out and then flush that stuff out with the Brembo fluid.
I was running the Prestone DOT 4 synthetic and apparently it sucks. LOL
Per Carbotech, I took a 2 inch abrasive disc and went over the rotors to get the old brake material off before I put the new pads on and bedded them in.
