Old 05-23-2010, 04:53 PM
You will limit your steering running a 10" wheel on the front with that subframe. A 9" with a 265 is a much better fit. but most of us will give up a tennie bit of lock to lock steering for them big ole tyres!
Frank Serafine
Old 05-25-2010, 07:58 AM
Bow Tie 67's Avatar
Bow Tie 67 Bow Tie 67 is offline
I'm not sure if my frame is a first gen, bought in spring of 2006 I believe.
I just drove the car yesterday with new 18 x 10 5.5 bs 275/40 tires and no problems, the big test will be pushing it at the track. Street driving so far no problems.
Matt
Project: " Chain Reaction "
A.K.A. " BIG " by wife, biatch in garage.
1969 RS Camaro, L92 T56, Chassisworks sub, Quadra-Link, Bear, Ford 9".
Old 06-05-2010, 10:59 AM
steve671's Avatar
steve671 steve671 is offline
So with a 265 on a 9" front wheel, would a 6.25" bs be best?
Compared to 6.75"bs on a 10", it would take a 1/2" off both the inside and outside correct?
Old 06-06-2010, 08:38 PM
Blake Foster's Avatar
The Cheassisworks clips is stock track width. Your going to need 6.75" BS on that 10" front wheel
the green sped tech 69 camaro runns 10 with a 7" BS our new car runs a 9 with a 6 bs same tire size 275 30 20 on both cars, i think the 9 actuallu looks better with the 275 on it, if your doing a10 then i would look at a 285 or maqybe a 295 front wheel, you will probably have to do some steering stops, but Oh well.
Blake Foster
www.speedtechperformance.com
Old 06-14-2010, 04:53 PM
steve671's Avatar
Originally Posted by Mikamaro View Post
If I increase bs 1", I'll hit the frame/inner well before lock w/ the front of the tire. Would I have to limit the steering?
What did you end up doing?
1969 Camaro https://www.pro-touring.com/threads/...9-Camaro-build
1967 Nova
Old 06-14-2010, 05:43 PM
Mikamaro's Avatar
Mikamaro Mikamaro is offline
I have taken no action other than fit it up. I need to dive into my minitubs. When it comes time to replace the rear wheels tires, I'll decide if I change all 4 or just the rears. All depends on the cash flow situation in a few months...
Old 06-14-2010, 05:49 PM
steve671's Avatar
Cool, I have the same subframe and am trying to figure out the best backspace for a 18X9" with a 275. I want the car to be prety low, and based on Franks recommendation of a 6.75"bs for your 10", I was thinking 6.25" for my 9" but I am having a hard time confirming this. So I was just checking to see if you got something to work. Thanks.
1967 Nova
Old 06-15-2010, 05:19 PM
DriverzInc DriverzInc is offline
Based on the measurements the original poster came up with, I'd agree that a 9" with a 6.25" should work as well. Have you measured the distance from your rotor hat to the outer fender? What do you come up with?
Old 06-15-2010, 07:55 PM
steve671's Avatar
Thanks Jon. Unfortunately the subframe is not in the car yet, it's sitting on jackstands.
Maybe Mikamaro would be so kind and take this measurement?
1967 Nova
Old 06-20-2010, 05:38 PM
steve671's Avatar
Ok, I put the whole thing together, swapped out the subframes and measured this. It is 5-5/16" from the hat to the unrolled fender lip.
Base on this measuremeant, to make the 18X9 with a 275 the same distance to the fender lip as the factory ralley with a 235, the BS needs to be 5.75". I am considering going 6.0" to give me a quarter inch more clearance because I am going to be pretty low.
Does this sound right?
1967 Nova
