Go Back   Lateral-g Forums > Technical Discussions > Trucks
Old 08-22-2010, 11:36 PM
tobenk tobenk is offline
I was wonderin too.
Old 09-01-2010, 08:20 AM
N2TRUX's Avatar
N2TRUX N2TRUX is offline
Originally Posted by SS350Sport View Post
I want to keep the truck quite inside and thought these might induce some road noise into the cab. What are you thoughts?
Lets start with how sweet the frame is looking. I love the sheen that the Summit paint has. I have been using Eastwood products for years, but I think they just got bumped out.
Unless you want potential for resonance transfer in to your cab I would not use Urethane bushings. You might have a bit more body flex with standard rubber bushings, but they will absorb exhaust resonance much better than the rock hard urethane bushings.
Old 11-21-2010, 09:25 AM
SS350Sport SS350Sport is offline
Default Update
I started cleaning the underside of the cab last night, in preparation for paint.
Here are a few detail shots of the frame.
Old 11-21-2010, 04:48 PM
BayouSS BayouSS is offline
Looking good.
Bill Haynie
Old 11-22-2010, 05:11 PM
Lookin good man.
Old 12-04-2010, 11:52 AM
Default Before & After @ 8hrs
Here's a before & after, took about 8 hours off and on after work. Does anyone know if any OBS cabs came with a heat shield for the drivers side under cab. I plan on running long tube headers with cats right at the collectors. Should be easy to fab one also.
Old 12-04-2010, 12:54 PM
Stielow's Avatar
Stielow Stielow is offline
I have a question, is anyone or has anyone ran the polyurethane cab mounts from Energy Suspension? I bought a master kit and it has cab mounts. I want to keep the truck quite inside and thought these might induce some road noise into the cab. What are you thoughts?
I would use the stock replacement cab mounts. The GMT400 GM chassis is sensitive to the cab mounts. The build looks good I always liked those trucks.
Mark
Old 12-04-2010, 01:13 PM
double
Old 12-05-2010, 07:26 PM
ccreddell's Avatar
ccreddell ccreddell is offline
My problem has always been that I hate it when the body lines dont line up. The stock mounts sag after a time and then the bed sits higher than the cab. I would run the urethane mounts and deal with the sound issues with dynamat or something.
Old 12-25-2010, 11:07 AM
Default Merry Christmas to me.
Courtesy of the big brown truck & Summit Racing. I am starting to put the motor back together. I bought a small cam Extreme Energy 249, I want the truck to be reliable and tame. I also went with a set of Headman Elite long tubes, 14ga tubes, 3/8" flanges. These things weigh as much or more than the stock manifolds.
