Old 11-18-2010, 03:57 PM
Originally Posted by compos mentis View Post
Red is good.
Skippers,
It's the closest I'll ever get to a Ferrari!
Old 11-18-2010, 04:34 PM
Lenie's Avatar
Lenie Lenie is offline
My new screen saver......
https://lateral-g.net/forums/atta...7&d=1285551320
until you get yours done Greg
I'm gonna like seeing this one in person once your finished.
Lenie
Old 11-18-2010, 04:44 PM
That's Charley's "Stacked".... just a killer '32!
Mine will be just a mild resto rod... for cruising around. Easy to drive... and a just for fun build. One of the reasons I didn't go hotter on the engine.
Old 11-18-2010, 07:50 PM
Greg.. I like the plan... keep it simple so you can actually drive and enjoy it before 2017.
Old 11-18-2010, 09:07 PM
Dave -- That's the reason I'm not building it (or re-doing it). I want to drive it this spring!
Old 11-19-2010, 12:33 AM
Git er dun quicker and drive to RTTC
Old 11-19-2010, 08:03 AM
Tell ya what Dave... I'll buy you airfare and you come up here and drive 'er down with me! A roadster going over Mt Shasta in late February should be a hoot!
Old 11-19-2010, 08:31 AM
fleet's Avatar
fleet fleet is offline
Since this project is snowballing...sounds like a job for Quadradeuce part deux ala Weld.
Lookin' forward to that.
Old 11-19-2010, 09:00 AM
Snowballing? I have no idea what you mean. Let's recap the work being done to my 600 mile fresh "re-deuce":
Body removed from chassis
Rear end and all mounts removed from chassis
Minor body repair
Install new Kugel Champ quick change
Check Kugel IFS for proper caster installation - cut and set up properly if required
R&R dash and gauges
Modify Steering column drop
New Steering wheel
R&R fuel tank for internal EFI pump
Check and R&R all wiring
Repair floor area and relocate emergency brake
Flatten floor space in trunk
New Motor
R&R T56 with TKO 600 5 speed
New flywheel - clutch - driveline
New Inglese EFI 8 stack
Custom Stainless Steel polished headers and exhaust - using V clamps
Check and relocate motor if required
Install MSD
Install Joe Hunt Magneto
New Wheels - Schott Velocity's
New tires
New square weave carpet
R&R grill shell
Fabricate new pan area in front of grill shell between front frame horns
Fabricate fan shroud and new electric fan/s
R&R hood mechanism
Remove hood sides
Add leather hood straps (4) with springs and buckles
Fabricate console with cup holders and push button start
Fabricate light bar and install new Commercial style headlights
Paint engine and transmission
Complete paint of frame
Paint other parts as required
I might be missing some items requiring additional attention.
Old 11-19-2010, 09:20 AM
ccracin's Avatar
ccracin ccracin is offline
Minor body repair
R&R dash and gauges
New Steering wheel
New Motor
Install MSD
New tires
R&R grill shell
R&R hood mechanism
Remove hood sides
Psssst.... You done yet? That's just a simple punch list! EEEEAAAAHHHH!
Chad
Instagram - @cctek
68 Chevy Pickup Project
