Old 11-24-2010, 01:09 PM
96z28ss's Avatar
96z28ss 96z28ss is offline
Started work on the front inner fenders also. I wanted it to match the frame better and make them a bit wider for more tire clearance.
There is no need for the control arm hole to be so big so it was brought out to the edge of the control arm mount about 3/8" clearance all the way around. Also the back side was lengthened so it covers the sub frame more, keeping some tire debris off the subframe and firewall.
Tim is real good at working metal. Shrinking, stretching, and using a big hammer he made the crown in the metal and gave the front inner fenders more tire clearance.
There will be a bit more detail in them but that will be on the next update.
Here is the driver side almost done.
1969 Camaro LS2/T56 D1SC
www.automotivedesigneng.com
Old 11-24-2010, 01:19 PM
Childs play.....
If your name is Tim Badboy Bruning.....
Old 11-24-2010, 01:59 PM
awr68's Avatar
awr68 awr68 is offline
Very nice work Tim!
Thanks for sharing, Bob! It's a much needed detail when using those frames/suspension!
Tony
'68 Camaro
Old 11-25-2010, 05:36 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
Looking really good Tim. Nice work.
Old 11-25-2010, 07:11 PM
syborg tt's Avatar
Looks great
marty-mj
Old 11-25-2010, 07:38 PM
Have fun aligning the car....
Old 11-25-2010, 08:09 PM
96z28ss's Avatar
Why? It won't be that bad and I don't plan on doing it too many times
Old 11-25-2010, 08:16 PM
It looks like it's going to be tricky getting shims in place.
Old 11-25-2010, 08:59 PM
coolwelder62's Avatar
WOW!! looks awesome.Just get it alined before you bolt on the front sheet metal.That's what I did and worked out real nice.
Old 11-25-2010, 10:02 PM
96z28ss's Avatar
nah the shims will go in from outside the frame rail plenty of room to get them in and out.
