Old 11-27-2010, 08:19 PM
pavell's Avatar
pavell pavell is offline
Default CPP 13"/12" Brake Kit
http://cgi.ebay.com/ebaymotors/1968-...Q5fAccessories
has anyone used this brake kit? how is it? They say better stopping power than C5 brakes?
I'm just building a mild street car that may one day see light track duty.
it seems like its a good value for the money vs. spending $2,000-$3,000 on wilwoods.
Any pictures on a car?
Thanks guys.
Old 11-28-2010, 12:08 PM
markss28 markss28 is offline
Kore 3 C6 kit. its under 2gs for everything
Never Stay Stock
Old 11-28-2010, 12:39 PM
ma73z's Avatar
ma73z ma73z is offline
I've installed two of these kits on other peoples cars, they aren't bad but on my car I will spend money elsewhere, probably kore 3. I've never posted pics on here, maybe it's time to learn but I can e-mail you some if you'd like.
Old 11-29-2010, 12:49 PM
Coursey Coursey is offline
Is a thread for an install on a nova.
http://www.stevesnovasite.com/forums...d.php?t=140977
Old 11-29-2010, 04:06 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
Haven't used those but I believe the calipers are cast steel. Do yourself a favor and call Tobin at KORE3 or look around the site to compare products you will be happy. I WAS!!! I went with the C6 Z51 340mm front and 330 rear kit.
http://www.kore3.com/products.php?cat=11
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
Old 11-30-2010, 04:07 AM
Chevy Kid Chevy Kid is offline
Those are Tahoe cast iron calipers. The front rotors are their own design, apparently not off the shelf items.
Tim
Old 12-01-2010, 10:25 AM
Apogee Apogee is offline
For what it's worth, I'll throw my $.02 in the hat. It's important to keep in mind that "stopping power" is not necessarily a meaningful measure of a brake system since ultimately it's your tires that are the limiting factor, not the brakes. A properly set up brake system should be able to achieve lockup at reasonable pedal inputs...anything beyond that doesn't do anything for you.
When CPP says that their big-brake kits have 60% more stopping power than a C5/C6 kit, they appear to be strictly referring to the difference in piston area between the C5/C6 (3.97 in^2) and Tahoe calipers (6.58 in^2). While you could say that they are technically correct in their statement, it is completely misleading in my opinion to state it in such a way since brake torques are a function of pressure and piston area (negating pad CoF and rotor diameter for the sake of not needlessly complicating this argument), not piston area alone. To be clear, if you supplied both calipers with the same pressure of 1000 psi, you would get more clamping force from the larger piston area since Force = Pressure x Area, 3970 versus 6580 pounds of force respectively. If lockup occurs at 4000 pounds of clamping force, what does the additional "stopping power" gain you? If you answer nothing, you would be correct. Most OE disc brake applications on GM muscle cars have more piston area than even the CPP kits at 6.77 in^2 with the 2-15/16 single piston calipers, so if you like their argument, then you should stick with your OE discs.
The reality is that if the master cylinder is properly sized for the calipers, they can both be made to generate similar clamping forces and brake torques. A performance brake kit should provide larger rotors with more thermal mass so that you can brake harder, longer, without any appreciable decrease in performance. If you just want to decrease your stopping distances, invest in the stickiest tires you can find and ABS.
Tobin
KORE3
www.kore3.com
Old 12-01-2010, 08:33 PM
pavell's Avatar
yes Apogee; your absolutely correct. CPP's marketing at it's best.
