Old 02-15-2011, 05:48 PM
Tincup's Avatar
Tincup Tincup is offline
Very nice build, doing a B-body is easy, try doing all the same stuff to an early A
Old 02-16-2011, 06:31 AM
wedged wedged is offline
Thanks. The car itself wouldn't make any difference in difficulty to me. Working around the paint being already finished is a bit of a pain though .
Old 03-03-2011, 06:49 AM
These are the brackets I made to fit the lower radiator mount cushions on the stock SRT8 Charger radiator that is being used. They bolt to the radiator support. The a/c condensor from the Charger will be mounted on the front of the radiator support.
the reworked torsion bar crossmember is made out of 1/8" steel on all 4 sides & fully welded. The torsion bars are not being used of course.
With one 2 gallon pail of Lizard Skin sound deadener, I was able to spray the entire top side of the floor pan, rear wheel wells & firewall, inside both doors and both 1/4 panels as well as the bottom of the floor pan between the sub-frame rails from the fire wall/floor pan seam to just in front of the rear axle and the area above the fuel tank.
next is a coat of Lizard Skin heat insulator
Old 03-03-2011, 08:44 AM
It looks great. I would like to use the heat insulation on my interior before I put the dynamat down. That came out nice.
Old 03-07-2011, 09:12 AM
The engine and trans is back in place.
Old 09-21-2011, 05:58 PM
R.A.D's Avatar
R.A.D R.A.D is offline
how is this coming along?
LIKE THE MAN SAID "EYE BALL IT"
http://fordodgetrucksonly.forumotion.com/
RIDESBYDESIGN.COM
Old 09-23-2011, 10:05 PM
I've done a little here and there as I've had some time. I've done some fitting of the stainless steel gas tank and worked on making the support straps. Not too much else though.
Old 09-24-2011, 03:50 AM
R.A.D's Avatar
Talking
thats too bad. sounds like your stretched a little thin
RIDESBYDESIGN.COM
Old 10-23-2011, 04:02 PM
I finished making the stainless straps for the stainless tank and also started running the fuel line from the filter/regulator to the front of the car.
Old 10-23-2011, 04:03 PM
A while back I had the brake booster rebuilt. It's just bolted in place loosely for now.
