Old 05-13-2011, 06:10 PM
^ yeah I'll bet. I've got some r888 335s if you want to do some horse tradin'...(not that they'd fit )
How old?
Old 05-13-2011, 06:58 PM
Track Junky's Avatar
[quote=coolwelder62;347829]
Gaetano,I have started working on a new sub frame.That should let me run a 335 up front on a 12 inch wheel.You might want to wait.
Scott, I think 315's is as wide as I want to go up front. If I go 335's up front I will have to do the same for the rear and I dont want to relocate leaf's. Thanks though, looking forward to getting your subframe some time in the near future.
Gaetano Cosentino
Old 05-15-2011, 09:57 AM
z4me69 z4me69 is offline
Did you move the shocks in?
Old 05-21-2011, 11:04 AM
The transformation is complete. Finally got my R888 315's delivered and the Z06 wheels on all four's. I had to cut the rear wheel studs for the hubcentric adapters so I will be pulling axles to install correct length studs.
Gaetano Cosentino
Old 05-21-2011, 11:22 AM
Shocks were moved in-board but still on the outside of the frame rails.
Gaetano Cosentino
Old 05-21-2011, 11:26 AM
Car looks great with those wheels. What size front tires?
Old 05-21-2011, 01:56 PM
Thanks Dave, fronts are 275/40 17's.
Gaetano Cosentino
Old 05-21-2011, 06:22 PM
garymac69's Avatar
garymac69 garymac69 is offline
I sure would like some pictures of the shock installation if you get a chance. I've been trying to figure out the shock location problem before I start a mini-tub project on my '69. I was wanting to go as large as possible without relocating the springs.
Have you had a chance to "push" the cornering to see if the 315's rub on the springs?
Old 05-21-2011, 09:00 PM
Your not going to be able to corner the car and not rub quarter panel without rolling lip and adding a watts link. I'll take some pics of shock mount outside of frame rail and post them tomorrow.
Gaetano Cosentino
Old 05-22-2011, 04:10 PM
garymac69's Avatar
Default Watts Link
My quarter's are rolled already. I'm running a 275/35/18 on the rear now. I thought a Watts link might be needed. What control arms, etc are you using to run 275's on the front? Do you have the turning radius limited a lot?
Thanks,
Gary
