Old 06-23-2011, 10:10 PM
Musclerodz's Avatar
Originally Posted by vinz68 View Post
Mine is clear as glass. The windshield does flex a little at high speeds. Nothing to complain about.
what thickness do you have. I know it comes in a couple of thicknesses
Mike Redpath
Musclerodz & Customz
facebook page
Old 06-23-2011, 10:41 PM
TheCntrion TheCntrion is offline
thanks for the responses guys!
it seems like most people prefer the percy's. They require trimming to fit. I noticed the harwood windsheild and windows can be purchased as an exact fit, no trimming required. I like the sound of that. I am capable of trimming but I would rather save the time for other things. Those harwood windows of course come at a higer cost...
am I missing anything as far as trimming goes? do the cut to fit pieces not fit?
Old 06-23-2011, 11:34 PM
Musclerodz's Avatar
they are left oversize for the customer to fit as needed. it also adds cost when someone else trims to fit. What percy's has over the others is the coatings on them that prevent scratches.
Mike Redpath
facebook page
Old 06-26-2011, 12:24 PM
Yenko boy Yenko boy is offline
On average how much weight are you guys with lexan windows installed.
Old 06-26-2011, 08:09 PM
3_z28camaro's Avatar
3_z28camaro 3_z28camaro is offline
An additional question about fitting the lexan flush, once it is shimmed up what do you use to fill the gap between the window and the body? Can some the that weatherstripping stuff that OEM uses be cut to fit?
Also is it possible to have the lexan tinted like the original green?
1971 RS Camaro
Old 06-26-2011, 10:44 PM
Track Junky's Avatar
Weight savings is 30 lbs up front, 20 for the rear.
Gaetano Cosentino
Old 06-28-2011, 09:33 PM
I just saw this post, It is not a lexan window, but is shows how windows can be fit flush. Also how it is trimmed with weatherstripping. Now I can appreciate the difference between trim to fit and OEM fit. (pics are not mine, Re posted from a different thread)
Old 11-30-2011, 12:17 PM
jamesinark jamesinark is offline
Default Where you get them?
Where did you purchase the percy's lexan?I was under the impression that the Harwood windows were also coated,but I may be wrong as I looked at quite a few sites and found more than one that was coated.I still haven't found the link.I also think I saw a kit in Summit or Jegs.Can.t remember if one or the other was coated.Any info would be appreciated.
Old 12-10-2011, 05:57 PM
ProTouring442's Avatar
I have my glasses coated with a "scratch resistant" coating, but I inevitably manage to scratch them at some point, and I am forever scratching my watch crystals, I cannot imagine a plastic windshield and I ever getting along.
Shiny Side Up!
Bill
You ever wonder what medieval cook looked at the guts of a pig and thought, "I bet if you washed out that poop tube, you could stuff it with meat and eat it."
Old 12-14-2011, 11:51 PM
I know that lexan for the street seems to be a little overboard for some ,but then I also have started to setup a jig to channel the body down over the subframe and the rest of the tube frame as well.I as well the person started this thread may want to lose as much weight up high as we can to lower the C/G.I worked as a aircraft A&P mechanic for quite a few years and am familiar with the problems Lexan presents as well as the advantages it provides as well.I also can scratch just about I own but some of the coatings that are avaailable now are quite capable of holding up for fairly long period of time.They also don't shatter upon impact with debris at higher speeds.I would still like to source a retailer for the Percy's windows.Any one got a link or source they are willing to share?Appreciate it.
