Old 08-01-2011, 08:36 PM
g356gear's Avatar
g356gear g356gear is offline
Default COMP cam magnum rocker nut failure
So I took the car out for a little spin today. I had installed Magnum roller rockers , guide plates and pushrods about 100 miles ago. I have a medium lift hydraulic cam in the motor....nothing too radical. I left from a light with a little of go petal and the car popped a couple of times and I backed out right away. The car immediately felt like it was down a cylinder. I pulled over and checked for anything odd. There were not any strange noises at idle and oil pressure was still good. I went straight home and could tell something was off in the motor. If I brought up the RPM's, I would get a little rattling out of the drivers side front of the motor. I let it cool down and pulled the plugs to check for anything nasty. #1 plug was black and wet, others all light tan and dry. I pulled the valve cover and found the pics below.
Has anyone seen this from COMP products before? Any ideas on a better product that's not going to do this on another pushrod? Needless to say the metal is nowhere to be seen in the cylinder head. I am hoping it's in the pan. I have a magnetic plug so my fingers are crossed.
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 08-01-2011, 08:52 PM
Is it just me or is there a serious lack of oil up top in that motor.......
Old 08-01-2011, 08:59 PM
bigtime's Avatar
bigtime bigtime is offline
I see that a lot from my customers tightening up the set screw then overtightning the whole deal by pulling on the adjuster nut to make sure its *tight*. This actually puts all the pressure on the lower threads of the adjuster nut and it cracks.
Old 08-01-2011, 09:01 PM
g356gear's Avatar
Originally I had it adjusted at 1/2 turn past snug and it popped a little. When I adjusted to 1/4 turn past snug it ran much better.
Old 08-01-2011, 09:08 PM
bigtime's Avatar
Hydraulic cams only run preload to keep the noise out. The more preload you run the better you chances of getting the lifter *pumped up* if you float the valves. If you plan on takeing it past 6500 rpm adjust them to zero lash. othe rthan the 1/4 turn of preload is fine.
As for you black and wet in that hole it would most likely be from oil going past the valve guide and seal. Since you lost the intake rocker the piston was trying to suck on that stroke yet had no air/fuel.
Old 08-01-2011, 09:11 PM
g356gear's Avatar
I am using the stock studs with the COMP parts. I wonder if maybe the stock studs need to be upgraded to a longer stud to get more thread engagement for the adjuster nut and take off some of the stress.
Old 08-01-2011, 09:13 PM
bigtime's Avatar
The set screw in the adjusters do look like they are low. I use ARP ones on BBC engines we build.
Old 08-01-2011, 09:14 PM
Your valve adjustment and what he is referring to are two different balls of wax. I'm assuming this is a hydraulic cam? Adjust the valve with the set screw loose, snug up the set screw, and then give the nut a hair more with a 9/16 wrench. If you are using a big ratchet or a super long wrench, you could over tighten the poly locks and crack them just as he said.
Old 08-01-2011, 09:15 PM
g356gear's Avatar
Maybe that's the issue......not enough length on the rocker studs. Any idea how much longer the ARP ones are over stock?
Old 08-01-2011, 09:18 PM
g356gear's Avatar
Yes....moderate lift hydraulic cam. I adjusted the nut down, set the screw, and gave the nut another 1/4 turn.
