08-26-2011, 07:45 PM
LS Conversion Motor Mounts
I need to buy a pair of Energy Suspension motor mounts for my LS conversion. The car was a factory 327 car and the stands are still original. What mounts do I need. If anyone has a part number, that would be great.
08-28-2011, 07:44 AM
some of it will depend on the oil pan, headers (if any), and cross member that you are using. On the motor mounts, you can use energy suspension poly mounts with most of the engine plates that are out there. Measure the width & height of the 327 engine stands- that will determine if you need the short/wide ot tall/narrow motor mounts. Try to get a kit if possible with headers/mounts/crossmember, oil pan etc. It will make life easier on the install.
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
08-28-2011, 07:53 AM
I have Stainless Works headers, a stock F-Body oil pan (notched for clearance), and Street & Performance plates.
08-28-2011, 09:30 PM
Hey Chris, measure the width of your towers and look at these dimensions.
http://www.energysuspension.com/prod...or-Mounts.html
Here is the part number I used with stock small block towers ENE 3-1114G. I have Stainless Works headers, 600 Series Lee Box and Autokraft pan.
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
08-29-2011, 03:47 PM
2-1/2" at the top of the tower. I guess I need the 2-5/8" mounts.
09-04-2011, 08:06 AM
mounts
Im doing a ls-2 in a 327 car also.hooker stock location mounts, SW headers, autocraft pan Im using energy-susp, # 3-1114
| Thread Tools |
| Display Modes |
Linear Mode
