Old 03-04-2006, 11:14 AM
Rick Dorion's Avatar
Rick Dorion Rick Dorion is offline
Default A ? for those with a DSE trunk mount battery kit
In laying out the template DSE provides, it seems that I will be using 4 of the 6 possible mounting bolts (top, bottom, two on left side) for the base since the outside (to the quarter) two are over the dropoff. This is in the right rear trunk area. Is this sufficient or am I missing something?
69 Camaro therapy program, 410, M22! SOLD
68 Camaro - SOLD
67 Bel Air - Hmmm.
Old 03-04-2006, 12:23 PM
rockdogz's Avatar
rockdogz rockdogz is offline
I can't remember which ones exactly I used, but I definitely wasn't able to use all of them either.
-Tom
camarorestoration.com
Old 03-04-2006, 12:28 PM
Sales@Dutchboys's Avatar
I believe that was the same for me also.....Ill have to look
dutchboyshotrods.com
269-823-2967
Old 03-04-2006, 12:31 PM
907rs's Avatar
907rs 907rs is offline
Rick, check out JT's build pics. It doesn't appear his is mounted that far outboard. I could be wrong though.......
Bill
Old 03-04-2006, 01:18 PM
Thanks, Bill. You're right. However, that puts his inboard mounting screws within the rear frame rail area, creating the same situation I'm posing but on the opposite side. Since the template is somewhat universal I think all is well. I'm just anal and also like symmetry! I want to know it's securely mounted.
68 Camaro - SOLD
67 Bel Air - Hmmm.
Old 03-04-2006, 09:10 PM
907rs's Avatar
I don't blame you one bit, Rick. The last thing you'd want is a battery flopping around in the trunk.
Bill
Old 03-05-2006, 09:32 AM
rocketrod rocketrod is offline
I was able to use all six bolts.
Old 03-05-2006, 11:48 AM
Can you elaborate? Thanks!
68 Camaro - SOLD
67 Bel Air - Hmmm.
Old 03-05-2006, 05:57 PM
My is positioned just like JT's. I needed to do this to mount my remote starter solenoid behind the battery. Needless to say the first hole I drilled was right in the center of the dead space in the frame rail. I have the battery mount out right and I could send you a pic so you don't drill any extra holes. Just PM me email address if interested.
Rod
Old 03-06-2006, 02:34 PM
Damn True's Avatar
Damn True Damn True is offline
It'd be great if you could post some photos of that. I'm wondering how that's gonna work as well.
