Old 02-02-2012, 05:14 PM
syborg tt's Avatar
Good Evening All,
Now that the shell is ready for construction it's time to post up the build outline. The main purpose of this car is to be a Mountain Bike Hauler since Mountain Biking is my first love with Car shows being a close second. The goal is to combine my the two and have the ability to drive to all of the nearby Good Guys Show and then on the way home hit the nearby trails. With that being said the car has to be dual purpose built. It needs to have a good set of street tire and then have an extra set of tires for the Good Guys Events.
Last year at Good Guys Columbus I fell in love with a very understated Mustang built by Pinkee's Hot Rods. If you pick up the last months issue of Popular Hot Rodding you can see the feature they did on the car. After reading that article I new I was heading in the right direction.
We are going to try to stick with the Vintage Race Car Theme without being overstated since I want to be able to street drive the car and not get pulled over every time I drive the car. And then there is that Mountain Bike issue where are we going to put the bike. Let's just say that this is going to freak some of you out and others are going to think it's awesome.
There are a couple other cars that has truly inspired me and this build. When the car heads to a track event I will print up some removable decals that will instantly make it look more like a Vintage TA race car. Kinda like this beast.
I have looked at this car for at the last couple years and I just love the look. So this car will also lend some idea's to the build.
another very clean build.
As for modification - most of them will be simple. The car will be mostly bolt together with very reliable part and most importantly something that if I break down they won't leave me Stranded.
Wheels & Tires
18 x 10 Rear - Billet Specialties MagG Wheels www.billetspecialties.com
BFG KDW2 - 295 40 18 www.bfgoodrichtires.com
18 x 8 Front - Billet Specialties MagG Wheels
BFG KDW2 - 255 40 18
Chassis
Ride Tech Coil Ride Suspension www.ridetech.com
MuscleBar Swaybar
Tie Rod Adjuster
G-Brace w/Cowl Brace www.pro-touringf-body.com
DSE Aluminum Body Bushings www.detroitspeed.com
DSE Subframe Connectors
Flaming River Steering Shaft www.flamingriver.com
Flaming Rivers Steering Box
Eaton Differential
TA Cover www.summitracing.com
DSE Brake Booster with reduced angle brackets
Kore 3 C5/C6 Brakes www.kore3.com
SS Brake Lines
SS Braided Brake Hoses
Quick Clips Line Clamps www.quickclips.org
Engine & Transmission
LS1 Short Block
Wegner Serpentine Alt P-Side www.wegnerautomotive.com
Edelbrock Motor Plates
Energy Suspension Motor Plates
Edelbrock Camshaft www.edelbrock.com
Edelbrock Heads
Edelbrock Intake
Edelbrock Carb
Edelbrock Shorty Headers
Floor Heat Shields
Edelbrock Stainless Exhaust Polished www.highspeedwelding.com
Bowler 4L60e Transmission www.bowlertransmissions.com
Bowler Billet Torque Convertor
Cooling
Afco Aluminum Radiator www.afcoracing.com
Afco Fan closeout
Vintage Air A/C Condensor www.vintageair.com
Fuel Delivery
Edelbrock Fuel Pump
Edelbrock Fuel Pressure Regulator
Black Push lock Earls fittings
Stock Fuel Tank www.goodmarkindustries.com
SS Tank Straps
SS Fuel Lines
Electrical
AAW Custom wire harness www.americanautowire.com
Tech Flex Wire Wrap www.techflex.com
Phantom Keyless Entry www.phantom-products.com
No Frills Billet Battery Front Mount Battery Tray www.hoodpins.net
Optima Red Top Battery
DSE Wiper Motor
DSE 7" High Density Lights
Interior
Autometer Guages www.autometer.com
Anvil Carbon Fiber Dash www.anvilauto.com
Vintage Air Factory Fit A/C www.vintageair.com
GM Tilt Column www.gmtiltcolumn.com
Precision Billet Brake Arm
Precision Billet Brake Pedal
Precision Billet Gas Pedals
Ride Tech Cage Tiger Cage www.ridetech.com
4 Point Restraints www.seatbeltplanet.com
4 Point Restraints - Rear Seat
Stock Door Panels
Rear Kick Panel Widened
Kenwood Head Unit
Kicker 5 Channel Amplifier www.kicker.com
Kicker 5 1/4" Round Speaker
Kicker 6 x 9 Speaker
Kicker 10" Subwoofer
Stock Buckets Seats Re-Foamed by Recovery Room Interiors www.recoveryroomrodinteriors.com
Stock Rear Seat Narrowed
Paint & Body Details www.kdhotrods.com
Anvil Closeout Panel www.anvil.com
Custom Works Radiator Cover www.customworksproducts.com
Ride Tech Fender Braces
DSE A/C Closeout Panel
Billet Kruzer Hood pins - black finish www.hoodpins.net
Stock Hinges filled, drilled & plated
No Frills Prop Rod
No Frills Custom Bike Rack www.highspeedwelding.com
Rocky Mounts www.rockymounts.com
Pictures hosted by www.garagescene.net
marty-mj
Old 02-02-2012, 05:52 PM
coolwelder62's Avatar
I love the New Mustang GT-R.that was so cool.
Old 02-02-2012, 05:54 PM
Some day I'd like to have a Shelby clone like that yellow one... what a kool car!
The Following User Says Thank You to GregWeld For This Useful Post:
syborg tt (12-15-2022)
  #194
Old 02-02-2012, 06:03 PM
That's a whole lot of Mustang influence for one Camaro HA!
Should be an awesome project.
John
'71 Nova (Build thread)
FFR Roadster
Old 02-02-2012, 08:51 PM
syborg tt's Avatar
I agree it would look nice in your Garage
marty-mj
Old 02-02-2012, 08:52 PM
syborg tt's Avatar
Can you tell what I am going to build next
marty-mj
Old 02-03-2012, 06:28 AM
Marty,The mustang's where really designed for GIRL's.
Old 02-03-2012, 07:36 AM
GrabberGT's Avatar
Im more interested in your plan for the bike rack. Im a roadie and have planned on using my car for trips to various races around the state. I love the idea of showing up in this snarling beast of a car amongst the other overly environmentally conscious riders in their gas sippers. (For those of you who are environmentally conscious, I offset my large vehicular carbon footprint with cycling to work and an electric lawnmower) I cant fit my bike and gear in the trunk and a trunk mount rack will not work. My only other option is to fit a removable trailer hitch and use a hitch mount rack or utility trailer. I like the utility trailer idea as it also would double for road trip duty to various auto events. The trailer hitch would be removable using as many bolts on the frame as necessary to ensure it is secure.
Chris
Its not a Vega!!!!
Old 02-03-2012, 10:02 AM
syborg tt's Avatar
We have a couple crazy idea's
Shoot me your e-mail and I will explain them. I am certain your not going to want to go down the road I am going. Way to extreme
marty-mj
Old 02-03-2012, 10:08 AM
syborg tt's Avatar
It's a Good thing I am building it for my daughter
marty-mj
