Old 07-09-2011, 06:21 PM
bulldog19 bulldog19 is offline
Received my mono to multi leaf spring kit from DSE yesterday so I have something to do tomorrow. One concern I have now with the installation of the longer shackles in the back what effect will this have on my shocks if any? I went 3/4" longer on the shackles.
John
68 Camaro RS Convertible Dual Quad 406 TKO600 Hotchkis TVSS SOLD
Old 07-17-2011, 01:26 PM
Ok so i have everything back together almost. I made the reaqr spring shcakle 3/4" longer and went with the DSE conversion kit and new lower spring/shock plates. My issue now is the bolt hole is about 1/2-3/4" below the shock am I ok to jack the rear up to get the shock bolt in? I have new shock bolts but just wanted to make sure this was the way to do it before proceeding.
John
John
Old 07-17-2011, 06:04 PM
JMitch19's Avatar
JMitch19 JMitch19 is offline
Is the shock to short with the suspension at full droop or with the car at ride height? If it is at ride height I think that would be a problem. If it is with the suspension at full droop it should be fine.
How does it look at ride height now?
Jason Mitchell
1971 Camaro 416 LT1 Project
Old 07-18-2011, 04:07 PM
Well it was to short when the car was up on the lift. I just put the car on the ground and the bottom of the shock is about 3-1/2" below the mounting hole.
As it sits yes I think I got the clearance I need. But i need to get the shocks bolted in and take a cruise with my family and see if this problem is something to cross off the list.
John
Old 08-02-2011, 04:01 PM
SUCCESS! I got everything bolted back together and torqued so we loaded up and headed out for a cruise and no RUB!! I hit a variety of bumps and now have no issues. The ride is a little firmer but I like it.
Here are a few after pics.
Thanks for all the help and advice!!
Now its time to fix the rattle in the exhaust system!
John
Old 08-02-2011, 04:48 PM
DriverzInc DriverzInc is offline
Old 08-02-2011, 08:33 PM
JMitch19's Avatar
Looks good. I thought the shackles would rise it more than that, but that looks just right.
Jason Mitchell
Old 04-30-2012, 01:05 PM
Before I took everything apart for paint I did an inspection and noticed a gap of about 3/16" between the top of the spring and the perch, the DSE supplied spacer was not thick enough. No big deal I had some plates made and filled the gap.
Took everything apart and painted re-assembled and did some running over the weekend and now the ride is not as firm and predeictable. Now hitting a bump either small or large the rear end is very bouncy almost like you have too much air in a ball. Tire pressures are @ 34lbs. Any suggestions?
I had to take car to interior shop this morning too have top fixed but I should have back by the weekend.
John
