Old 05-20-2012, 01:43 AM
Default Magnesium bellhousing -- yes or no
Please weigh in.
Predictable responses:
"Do you like your feet?"
"Is weight savings worth it to you?"
Anything else?
Old 05-20-2012, 01:52 AM
FETorino's Avatar
FETorino FETorino is offline
Uh WHY
if your flywheel lets lose at 7k you'll lose more than your feet bud.
It's your body parts so I say the weight savings is definitely worth it.
Rob in SoCal
Old 05-20-2012, 02:04 AM
Uh WHY
I guess I am curious what applications these make sense in then (yes, race cars). But do those cars have an extra layer of protection between the bell and the driver then? If not, why are they risking it and is a major failure common?
Old 05-20-2012, 08:57 AM
The higher the RPMs -- there will be a increasing risk of catastrophic failure.
If you're being paid millions to race and risk "everything" -- sure...
We're doing TRACK DAYS.... and paying for that privilege to boot! The compromise is building in a bit of reliability, and SAFETY, so we can continue to have fun.
Regardless of choice.... Drivers skills (seat time) will beat weight savings every time.
Old 05-20-2012, 11:19 AM
badmatt's Avatar
badmatt badmatt is offline
I dunno, I went mag, Tilton says they put there rep on it being stronger than an aluminum piece...
Im still putting a blanket around mine... 75 bucks for a blanket compared to loosing my legs? cheap insurance..
Matt
PS: My aluminum bell (no throw out) is 11lbs.. my mag bell with the throw out 8.2lbs.. the mag bell looks cooler though..
97 Sonoma "NERA": Pile O Sh*t. Literally.
Old 05-20-2012, 11:50 AM
I should have mentioned we already have a magnesium bell in hand so that is part of the analysis here. The Tilton 7.25" triple is already going in no matter what. Rated to 930 ft lbs with a sub-10 lb flywheel.
Yeah I get that but I gotta think the high dollar teams and drivers using this setups must have some sort of protection built in. Nascar is pretty damn serious about safety these days and with all the wrecks and failures the cars seem to protect the drivers pretty darn well.
Matt
A blanket. Ok there's an idea. Who makes the blanket you have? I figured there had to be something like that but did not see any reference to the term "blanket."
Yep my research shows the following:
Steel 21 lbs
Alum 12 lbs
Mag 8 lbs
But again, we already have a mag bell with the clutch kit.
Thanks guys
Old 05-20-2012, 12:44 PM
badmatt's Avatar
just the basic RCI trans blanket its SFI 4.1
buddy of mine has his glide blow apart... the blanket kept it contained perfectly.. and soaked up some fluid too! WIN WIN
Old 05-20-2012, 01:01 PM
MillerBuilt's Avatar
MillerBuilt MillerBuilt is offline
If you are trying to save weight, stick with the Kevlar over the Ballistic Nylon.....more $ for the Kevlar but I assume you are in it for weight savings since the bell is Mag.
Old 05-20-2012, 01:31 PM
Cool. I'll have to consider this and research some more.
Weight savings is nice but not a driving force over safety. If we didn't already have the mag bell, I'm not sure I'd go out and source one.
Thanks for the tip.
Old 05-20-2012, 05:11 PM
Thanks for the tip.
I completely agree, safety first! May wanna just shelf the mag and drop the necessary funds for a Quicktime?
I am not so sure a trans blanket is the correct application for the road course anyhow.....I am thinking the blanket will trap heat and raise tranny temps?
