Old 09-25-2012, 04:34 PM
ProPont ProPont is offline
Default Weld in roll bar to firewall supports
I am trying to find out who makes the welded in round roll bar supports that are welded into the firewall so you can unbolt the subframe. I have seen these used by a few shops. I hope I explained myself correctly.
Old 09-25-2012, 05:19 PM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is online now
I'm interested in a set too.
Old 09-26-2012, 10:26 AM
latoracing's Avatar
latoracing latoracing is offline
Make them. How do you want the tube to attach, like a swing out door bar, or just through bolted? A local machine shop should be able to turn you a simple part for the through bolt design. Don't know of any off the shelf items, other than the door bar adaptors from various vendors. If you can't get them done locally, let me know, I'll try to fix you up.
Old 09-26-2012, 12:03 PM
Hotchkis makes a bolt in unit.
Check with Brett @ fab53 he maybe able to make you a set.
Old 09-26-2012, 11:59 PM
oh you mean these....tube couplers?
Old 09-27-2012, 08:52 AM
CamaroAJ's Avatar
^^^^yes, those^^^^
They are very simple to make if you have a lathe, I just happen to not have one.
Old 09-27-2012, 09:07 AM
James OLC's Avatar
I can check with Matt to see if he still has the pattern in his CNC that we used for the OLC...
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 09-27-2012, 10:30 AM
Flat plate - two hole saws and a drill bit... cut the big round first - cut the inner - mark a pattern for the bolts - drill and finish...
Old 09-27-2012, 10:45 AM
ccracin's Avatar
ccracin ccracin is offline
I like to cut the little hole first, then weld the slug back in so that I can pilot the bit for the larger hole saw. Then carefully body saw the tack welds on the plug to remove. After that lay out the bolt pattern and try to hold the disk with your hand while drilling the holes with a uni-bit and air drill. After bandaging your hand and fixing the dent in your new fender after the drill threw the disk across your 3 car garage at 100mph debur and viola! Done!
ALL WORTH WHILE PROJECTS INCLUDE CUTTING, WELDING, BLOOD and CUSSING!
Seriously, not everything has to come out of a CNC machining center. Greg hit the nail on the head! Sometimes keeping it simple is the best solution!
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 09-27-2012, 11:00 AM
^^^^^^^^^ That is hysterical!
Can't tell you how many guys stop by to do a "little project" --- I pile some tools on the work table and tell them "have at it".
Amazing how many can't think thru the steps and cut the big pattern first then can't figure out how to cut the smaller hole now that they don't have a pilot hole.... SO then I have to rescue the thing by setting up the mill/drill and punching the small hole in for them. Takes longer to set up the machine than it did to do the work...
Most can't lay out a simple pattern --- or know enough to make the attachment piece and the plate and drill them together so the holes line up etc... let alone = clamp the piece and use a transfer punch...
I get some good laughs out of all this... and it's not because I'm a smart ass... I've made all the same mistakes!
