Old 10-20-2012, 10:40 AM
390 S code 390 S code is offline
Default 67 Mustang Fastback
HI guys ,
My first post i am building a 1967 390 s code 67 fastback ,car has been in Australia about 12 years when i purchased it ,it was in a sad state it had been repainted various times its original colour is silver frost . Have no history of its past life but someone at sometime had laid it to rest with 3 45 caliber rounds ,so i consider this its resurection . The rebuild so far .
Full body rebuild and repainted brilliant silver with argent silver lemans stripes.coil over front and rear suspension TCP 4 link rear . 330 mm front discs with late model spindles and 4 spot calipers .Engine is a 390 FE with a 4.125 stroke Scat crank H beam rods diamond flat top pistons 433 cu in .
Edelbrock heads with Dove tunnel wedge manifold running a F&B TRI POWER fuel injection setup with a FAST XFI management .Engine is being assembled and waiting on manifold to arrive from USA . Will post some photos on progress.
Old 10-20-2012, 11:44 AM
Default 67 S Code
Some build photos
Old 10-20-2012, 12:47 PM
Killer project... welcome!
FETorino is gonna love you.... he'll find this thread soon.
Old 10-20-2012, 01:00 PM
Yeah FE Torino found me on FE power forum another great sight . Like all of us i have tried to make the car something different especially with the Tri Power.You guys have some awesome builds .
Old 10-20-2012, 01:24 PM
More photos of the manifold
Old 10-20-2012, 01:51 PM
FETorino's Avatar
FETorino FETorino is offline
Yea it's a cool car for sure.
I think I may know who told him about this site
I can't wait to see how that tunnelwedge tripower runs. I bet it works pretty well.
Rob in SoCal
Old 10-20-2012, 01:56 PM
Killer piece. Is it relatively easy to tune?
Of course... recruiting more of your own kind.
Old 10-20-2012, 02:01 PM
FETorino's Avatar
Can't we just all get along.........
Rob in SoCal
Old 10-21-2012, 09:08 AM
Default Tri Power
Manifold will run 3x600 cfm throttle bodies with a progressive linkage . I have been told that on the 440 mopars that F&B have fitted this system too that they are very drivable .With the centre throttle body bringing in the torque earlier .As far as tuning it i hope the XFI FAST will bring this engine to life . Trans is a TKO 600 with 3.5 diff gears . As far as the Tunnel wedge manifold there were concerns with air speed but since it is fuel injected it should work OK. As you can see it has a large plenum what do you guys think .Car should have some under bonnet appeal with Cobra Lemans valve covers ,and a polished oval aircleaner when it all comes together i will post more photos .
Old 10-21-2012, 09:50 AM
FETorino's Avatar
Of course I love the car but I'm an FE Ford guy. Of course I don't know how anybody couldn't like the early Mustangs.
That TW would work fine even with carbs. The FAST system should make it very drivable as long as you know how to tune with it.
What are you going to run for wheels and tires?
Which TKO do you have the .82 or .64 5th gear. If you haven't bought the TKO yet I'd think hard about which one to buy. I'd say the .82 5th makes more sense. The one comment I'd make is with the OD 5th I'd go for a deeper rear gear unless you are running a really short rear tire.
Rob in SoCal
