Old 01-22-2013, 03:41 PM
marks914's Avatar
marks914 marks914 is offline
Regular User
Default Custom gauge packages only from NVU
NVU is the ONLY instrument manufacturer that can bring literally any style, size, shape and function to your dash with more features, details, style and function than you can find anywhere else. Need something a little different? The designers at NVU can create a custom setup that blend seamlessly with your vehicle style, build, and theme. With a warranty to back it up.
Need a retro-factory style with modern internals to communicate with your LS? No problem.
How about a one-off cluster to fit your one-off build? No problem
Backlit custom one-off graphics, full LED backlighting in any style font, color, background? No problem.
NVU has it covered: graphics, function, style, quality and features you can find nowhere else.
Give a call email or stop on by, the folks at NVU will be more than happy to walk you through the process. For more ideas and information check out the custom gauge set page on the New Vintage USA website.
Enough gab, here are some pics:
This customer wanted a Camaro inspired gauge set, but in KPH. Custom redline on the tach to the customer’s specifications, our exclusive “deadfronted” turn signals and indicators (black, invisible when off) all designed to bolt right in the factory dash.
This customer wanted to keep the feel of the 67 he was building so the designers at NVU came up with a package based on the 3-in-1 gauge sets with graphics emulating the original, but with a twist. Again custom redline, indicators, etc, all 6 functions in 2 gauges bolts right in.
Here is a Gen 2 Camaro package based on the Redline gauges. Custom redline, and customer graphics on the dials to match the rest of the vehicle. Custom programming for KPH speedo. All based on the Gen 2 Camaro packages and bolts right in the stock dash.
Now to take it to the next level, NVU can produce any graphic style, any color, how about this backlit carbon fiber dial
Not a Camaro, but this is a good example of how far a custom gauge kit can go. Graphics to match the Auburn, with custom floating cover bezel on the quad gauge, custom pointers and fine detail graphics.
This 67-69 GM truck is a good example of some things that make NVU different. Short sweep 3-3/8” fuel gauge, floating backlit dials on the larger gauges, custom pointers.
Here is an example of a retrofit. This customer had a 65 Corvette and wanted to use the stock housing. The engineers and designers at NVU came up with a modern blueline package that brought the dash into this century to match the updates on the car. Programmable speedo, backlit spun-metal dials and pointers. Custom programming and hand built cluster makes this dash a one-of a kind.
When its time to do something special for your build, that will help insure your investment against damage, and will also make the driving experience more pleasurable, remember NVU can bring that dash to life and create a truly special product just for you.
NEW VINTAGE USA
THE ORIGINAL PERIOD STYLED AND THEMED INSTRUMENTS
www.newvintageusa.com
Old 01-22-2013, 03:53 PM
NvrDun71 NvrDun71 is offline
Any offerings for 68'-72' Nova sweep style dashes?
71' Nova - LY6, T56
Old 01-22-2013, 04:55 PM
marks914's Avatar
Regular User
If we had a dash here I'm sure we could come up with something.
