Old 03-28-2013, 11:27 AM
HEEP's Avatar
HEEP HEEP is offline
Default Body Mounts - Solid / Poly / Rubber
Ok guys,
I'm at a point where I am ready for body mounts. I have already modified the frame and ready to install the body. What mounts are best. I have a set of rubber and poly, now I'm seeing solid out there for my Chevelle. What should I go with?
HEEP
Old 03-28-2013, 12:31 PM
We have done them with both the energy suspension bushings and custom aluminum body bushings..... in theory the poly is supposed to be better for cutting some vibration/noise transfer, but I would venture to guess you really wouldn't be able to tell the difference. Only drawback with a chevelle is that there are so many mounts required, it gets costly to machine a set.
My suggestion is use the poly ones. Don't bother with the stockers, you will have a headache with our body reinforcement bushings and clearances. The "stock" rubbers I can't even get them to fit into a stock, unmodified frame hole. Seems they aren't that great. The poly ones work great.
Tyler
HPI Customs
Manitoba, Canada
www.hpicustoms.com
Old 03-28-2013, 12:40 PM
HEEP's Avatar
Tyler,
I noticed that on the rings you sent with your kit. I could not get them to fit. Did you come up with solid mounts? I thought I saw something on your site about them. You want to PM me a price?
I have also thought about taking the rubber one to a machine shop and have them make some aluminum ones for me.
HEEP
Old 03-28-2013, 02:33 PM
Che70velle's Avatar
I went with the poly units. They are very dense, and as said above, you probably would not be able to tell the difference between the poly units, vs. the billet units, from the drivers seat.
Thanks Dad!!
Old 03-28-2013, 08:43 PM
DaleTx's Avatar
DaleTx DaleTx is offline
I went from worn out stock rubber bushings to solid aluminum. There were four bushings between the subframe and chassis and two bushings between the core support and sub frame (gen 1 camaro). After changing out all six original rubber bushings to solid aluminum I noticed a big difference in the way the car felt going down the road, and especially while cornering. The car felt much more stable in straight line and more precise on the steering.
I was not sure which way to go when I made the switch... and I was concerned about vibration or extra noise with the aluminum... but it is not a problem at all. If I had to do it over I would still go with aluminum. You probably couldn't go wrong with either poly or aluminum.
"If you wait, all that happens is you get older"
Mario Andretti
69 Camaro-Nutter Racing Engines/427CI LS2 sleeved/LS7 CNC ported heads/Custom cam/T&D 1.8 rockers/Manley crank/Manley H-beam rods/Weisco pistons/NRC Pro Series dry sump/Kooks/NA,92 octane,11.5:1- 672HP @ 6,900RPM, 566TQ @ 5,500RPM
Build Thread- http://ls1tech.com/forums/generation...ine-build.html
Old 03-28-2013, 08:48 PM
Sieg's Avatar
Sieg Sieg is offline
My Energy poly bushings make noise when torquing the chassis such as entering a driveway at an angle. I'd suggest greasing them before install.
Old 03-28-2013, 09:13 PM
JB64CHEVELLE's Avatar
JB64CHEVELLE JB64CHEVELLE is offline
I think ABC performance makes the solid mounts for the Chevelle, you might check them out.
1964 Chevelle SS,Ls1,T56,DSE 3 front&rear
1964 El Camino
1971 Chevelle SS
1971 Camaro
Old 03-29-2013, 07:39 AM
Che70velle's Avatar
Thanks for the tip Sieg! Never heard this, but will definitely do.
Thanks Dad!!
Old 03-30-2013, 06:00 PM
Heep,
I will shoot you a price on aluminum ones, we just got a CNC lathe so we can drop the price considerably due to time needed to crank em out!
If you can wait a little bit till its setup, I will hook you up!
Tyler
HPI Customs
Manitoba, Canada
www.hpicustoms.com
Old 03-31-2013, 07:14 AM
HEEP's Avatar
Tyler,
Just let me know price and time frame. I can set the body with rubbe and go back and replace with the aluminum ones later. I just can't fit fenders and stuff until I get whatever I am going to use.
Thanks,
HEEP
