Thanks Wayne, I appreciate the compliments!
					Originally Posted by waynieZ  Ed it looks nice and neat, and that's a nice test setup. |
Spent all of yesterday working on the car.  All fuels lines are done and pressure tested.  The supply line off the tank leaked during the pressure test.  I mixed up some soapy water and found it coming from the swivel nut portion.  I reassembled with a dab of thread sealant and that did the trick. Until that point I had left the male/female AN threads dry during testing..  I also got the II Much Fab fuel tank vent installed and plumbed and a few more electrical connections completed.  Hope to work more on the car tonight or tomorrow.  We have some misc remaining parts arriving on Tuesday so I’m hoping next week brings a more exciting update to this thread.
Between lat-g, google and you tube I’m starting to feel like I could rule the world!
 J/K But I have been learning a lot as I go with this project.  Pretty much everything I’m doing is a first for me. Yesterday I did find TDC for the first time in my life after some reading and watching a video.  I gutted an old spark plug, drilled it out, ran a piece of all thread thru it, then ground down a jamb nut so it would fit into the head threads.  Our old cast iron heads are laying around yet so I had something to test fit before trying on our aluminum RHS heads. I verified I was on the compression stroke by holding my finger over the #1 plug hole as I manually turned the crank. Then I inserted the piston stop into cylinder 1, placed a piece of tape on the balancer, turned the crank slowly until it stopped and marked the 0 location on the tape.  Then I spun it the opposite direction until it stopped and marked the 0 location on the tape again.  Wrapped a small piece of paper around the balancer, transferred both marks to it, matched up the two marks while folding in half to find the center point, then wrapped it back around the balancer and marked the center point on the tape.  Not too surprising but it matched perfectly to the original line on the balancer.
Took some time but since we bought the engine preassembled and I was not around the shop when it was installed I would have been making an assumption that it was right.  I’ve learned the hard way on this car that ASSumptions only cost us more money and time later.  Time to get the distributor installed and verify the plug wires still fit.
