Old 05-19-2013, 08:41 PM
pokey64's Avatar
pokey64 pokey64 is offline
Took Wednesday off to work on the car and also put in a few hours today. Wrapped up making the fuel supply lines and finished a few small items. Need to make a bracket to support the regulator yet. I also plan to pressure test all of the lines after rounding up a couple fittings to complete the testing manifold. I started tackling the wiring today. Have a handful components to get sorted out. Holley HP EFI harness, Fast Dual Sync Dis, MSD Digital 6AL box, Fuel pump/relay, and a Vintage Air unit. It was daunting at first but picked away at it and think I have a good plan now. I’m hoping to take another day off this week to keep at it.
//Ed
//1964 Impala SS
//1966 Chevelle (Family Hauler)
//1969 Camaro (Hers...)
Old 05-20-2013, 05:07 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Looks great Ed. Good job.
Old 05-23-2013, 03:30 PM
pokey64's Avatar
Thanks Tones!
Was out in the garage by 630 this morning. Other than stopping to mow the lawn it was a productive day on the car. Wiring is over half done and I got most of the fuel lines flushed and pressure tested. Should have time this weekend to keep plugging away.
Here’s pics of the pressure testing setup. I flushed the hoses with water then attached the valve side and blew them out with air. After that I attached the gauge and pressurized the hose. I let it sit a couple minutes listening for leaks and watching the gauge then bled off the pressure. So far no leaks.
//Ed
//1964 Impala SS
Old 05-23-2013, 04:56 PM
waynieZ waynieZ is online now
Ed it looks nice and neat, and that's a nice test setup.
Old 05-26-2013, 03:25 PM
pokey64's Avatar
This certainly isn’t as big of a deal as others are experiencing for weather or flooding this year. I just thought I’d share the “excitement” we had this morning. A crazy thunderstorm rolled thru last night. It was nonstop high winds, down pouring rain, lightning and thunder for 3-4 hours. When I got up this morning I hopped in my truck to go see if anything blew away at our office and was met by our friendly law enforcement on our washed out road.
We have approx 1/3 mile of gravel from the concrete road of our development to the city street. It crosses a small creek about halfway. (normally 2' wide) There is a pasture on one side and backyards of another development on the other. The barbwire fence of pasture caught debris and created a dam which backed up the water enough to top the road and wash out more than half the road width. I can tell from the knocked over grass that the flow was over 100’ wide at one point last night. This road is our only way in or out.
With it being a holiday weekend only one of the city maintenance guys were in town. Thankfully he was kind enough to come lend a hand. I spent over an hour pulling/digging away the debris on both sides to open up flow. It started raining again when I was out there so I got thoroughly soaked and covered in mud. I clipped the bottom 3 runs of barbwire covering the culvert to help prevent this from happening again. The cattle aren’t going to fit through the 24” culvert anyways…
The maintenance guy grabbed the city’s pay loader and made trips through town to bring 5 bucket loads of gravel to get us temporarily fixed up. We removed the big rocks around the gas line and backfilled around it by hand after it was inspected for damage.
The city has plans to pave this road when the pasture gets developed for housing. Hope that day comes soon since it'd be much nicer to drive the Camaro on.
//Ed
//1964 Impala SS
Old 05-26-2013, 03:26 PM
pokey64's Avatar
Thanks Wayne, I appreciate the compliments!
Spent all of yesterday working on the car. All fuels lines are done and pressure tested. The supply line off the tank leaked during the pressure test. I mixed up some soapy water and found it coming from the swivel nut portion. I reassembled with a dab of thread sealant and that did the trick. Until that point I had left the male/female AN threads dry during testing.. I also got the II Much Fab fuel tank vent installed and plumbed and a few more electrical connections completed. Hope to work more on the car tonight or tomorrow. We have some misc remaining parts arriving on Tuesday so I’m hoping next week brings a more exciting update to this thread.
Between lat-g, google and you tube I’m starting to feel like I could rule the world! J/K But I have been learning a lot as I go with this project. Pretty much everything I’m doing is a first for me. Yesterday I did find TDC for the first time in my life after some reading and watching a video. I gutted an old spark plug, drilled it out, ran a piece of all thread thru it, then ground down a jamb nut so it would fit into the head threads. Our old cast iron heads are laying around yet so I had something to test fit before trying on our aluminum RHS heads. I verified I was on the compression stroke by holding my finger over the #1 plug hole as I manually turned the crank. Then I inserted the piston stop into cylinder 1, placed a piece of tape on the balancer, turned the crank slowly until it stopped and marked the 0 location on the tape. Then I spun it the opposite direction until it stopped and marked the 0 location on the tape again. Wrapped a small piece of paper around the balancer, transferred both marks to it, matched up the two marks while folding in half to find the center point, then wrapped it back around the balancer and marked the center point on the tape. Not too surprising but it matched perfectly to the original line on the balancer.
Took some time but since we bought the engine preassembled and I was not around the shop when it was installed I would have been making an assumption that it was right. I’ve learned the hard way on this car that ASSumptions only cost us more money and time later. Time to get the distributor installed and verify the plug wires still fit.
//Ed
//1964 Impala SS
Old 05-26-2013, 10:15 PM
Better safe than sorry!
Old 05-27-2013, 03:30 PM
pokey64's Avatar
Thanks Ratman!
Holley's TB says 1000cfm. Yes, this system uses an O2 sensor.
//Ed
//1964 Impala SS
Old 06-09-2013, 04:36 PM
pokey64's Avatar
It was a long week of ups a lot of downs and some ups again. Sometimes these cars just kick you square in the nuts! Chased a ton of gremlins. Most of them came from a couple wiring issues (my mistake) and a usb driver/old ECU firmware issue (bought the Holley setup 2 years ago). Worked till midnight a couple nights and took some extra time off work. On Thursday I started over and worked thru the instructions several times and found the wiring issues. Friday morning we could get it to fire but it wouldn’t stay running. The timing was bouncing around and couldn’t be adjusted. In the afternoon we called Holley’s tech line and that’s when we figured out the firmware/software weren’t jiving. I hadn’t thought that was an issue since the computer and ECU were talking. After updating everything we prevailed and got the car running. It started off pretty rough but began to smooth out after we got the timing synced to the software. It is pretty cool to watch the system learn and self-adjust.
Unfortunately the issues kept us from making a local cruise night. On the plus side working through the issues has given me a thorough understanding of all of the new system components. Another positive thing from this week is that my dad came over last Sunday afternoon and Monday evening to lend a hand. We run a business together but haven’t spent that kind of personal time together in years. Really hope to keep that going.
Still have a list of things to button up before the first drive. She’s getting close but time for a short breather.
//Ed
//1964 Impala SS
Old 06-09-2013, 05:06 PM
Awesome Ed....
The time spent with "others" doing these projects -- to me -- is the very best part of the whole deal.
